Question about Rheem 40 Gallon FVR NATGAS Water Heater 6 YR 22V40F1
Rheem 40 gallon gas-pilot light turns off every day and i have to light it on a daily basis. I light it in the evening and it eventually turns off the next day sometime after showers are taken
    President:
  • 1,865 Answers
Replace the thermocouple
Posted on Sep 27, 2009
I have a 40 gallon natural gas operated Rheem manufactured GE smartwater that has been shut off since pilot could not be lit. I would like to lit the pilot but I would like to know if I should switch the...
Not enough information is given.
Add a comment any time.
Why did water heater turn off?
If water heater was exposed to flammable vapors like gasoline, paint thinner, paint, leaking gas line, etc, then the 'single use gas shut off' might have tripped.
If water heater is older and the burner parts never cleaned, then combustion chamber can experience overheating, and that can trigger 'single use shut off.'
Instructions for lighting water heater should be printed on side of heater.
Follow the instructions and see if water heater will light.
Then check if flame is clear blue. If flame is yellow-orange, then burner parts need to be cleaned.
If water heater will not light, then combustion parts may need to be cleaned, and air intake cleaned, and 'single use shut off' could also be tripped.
Also possible that gas control valve thermostat is bad.
Open following link to help identify gas valve and see illustrations and read information about cleaning combustion parts:
http://Waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Sep 10, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
My Rheem 40 gal. LPG water heater has sat for two years. When I attempt to light the pilot manually, it goes out after I release the push button valve knob?
The pilots have to warm up, hold that button down for a min, then let it go, it should stay on. Then crank up the pressure, it should light. If you are worried about it, call your gas man, he will check it out. Hope this helps.
Mar 31, 2010 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
How do I light my Rheem water heater if my peizo ignitor switch isn't working
Remove the burner access cover under the control valve. Press the pilot light button (gas control) and hold it down. At the same time, light the pilot. Continue to hold the lighting button for a few seconds until the thermocouple heats up. Release the button. Twist the gas control knob to the ON position, and the burner should fire up after a few seconds. Replace the access cover. Good luck.
Feb 09, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light won`t stay burning on my hot water tank. I replaced the thermacoupler;no difference. It is a Rheem Gauardian system ''Fury''. 40 gal in a wellsite skid trailer. Thanks
The thermocouple is a screw in type or 2 wire. You can check the dc MILI volt output with a multimeter. It should probably make 500-750miliVDC when heated. Be sure no plastic from the thermocouple wrapper was on the threads, will not work like that. To light did you push and hold the valve for 30 sec after lighting the pilot then turn to run after the pilot was burning? There is a slight chance the gas valve is bad but not likely. Check the wireing on the thermocouple to the gas valve.
Oct 19, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem Fury 42V50-40F. Piezo ignitor will not light the pilot light. A thousand clicks, still won't light. Mfg in 2005. Gas valve is on. Knob set to pilot, red button pushed --- I know how to light a...
Sometimes it is necessary to turn the temperature dial all the way back to the coldest setting with the gas valve in the off position in order to reset the safety on some gas water heaters. Give it a try
Jul 11, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Can no light up a new Rheem 22V40FN water heater
Air in system. Make sure there is no sources of ignition and loosen the supply line at the heater and purge all air. Mske sure your source valve is open. then turn off yje heater after tightening the line. Let sit in off position for 15 minutes. Then turn therm knob to on slowly and then over to pilot, depress pilot button and hold a ffew seconds. Pilot should light. If so, hold for a few and then release and turn ti on position. Good Luck.
Jun 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
No Hot Water in morning
Remove the cover then the access cover, then you can see inside,
the pilot light is probably out.
If out turn the gas off, then get a long match, grill lighter,or piece of paper ready to light, you should be able to see the little thin
gas line that runs inside the tank and see where it connects to,that is where you need to light, now that you see where to light, turn gas knob to pilot, and press down and at the same time light the pilot.
( blow into the pilot area before putting match inside to make sure no gas has built up inside) Hold down the knob for a minute then release, if pilot goes out try again and hold down longer, if you hold it for 3mins and it does not stay lite, the thermocouple is bad and you will have to replace it.
Apr 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 40 Gallon FVR NATGAS Water Heater 6 YR 22V40F1 Logo
222 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
