Question about Refrigerators
Maytag bottom freezer. Freezer is cold but fresh food is warm.
  • 909 Answers
Almost certainly your internal evaporator fan is stuck due to a build up of ice on the evaporator. Hoping the fan is not damaged, suggest you switch off for 12 hrs to allow proper defrost, then retry. No airflow will cause this. Normally if freezer door is left open slightly, it will create this scenario.
Posted on Sep 27, 2009
The freezer is running and cold, the refrigerator seems to be getting warmer like as if the cold isn't transferring. Is there a fan suppose to be running or what?
It is quite common for a refrigerator to begin the first signs of a defrost problems once he fresh Food section begins to warm. Auto Dampers are an additional component to check while searching for the true reason for Fresh Food compartment warming. First look inside the freezer compartment and and see if there is a layer of frost building on the rear wall. If yes you will need to manually defrost unless you have anothr place to store the freezer goods. Unplug refrigerator and then remove the rear panel of freezer to get a good look at the snow covering your evaporator coils. Defrost with a hair drier. Now we need to look for the cause Auto Damper, Click here for the photo location of these parts=> MSD2756GEW Controls Section the adaptive defrost control is most likely the problem and is listed in the photo as location 13 and the auto damper
61005971 Damper Control Assembly
61005988 Adaptive Defrost Assembly
The Auto Damper model refrigerator has two controls and both have capillary sensing.
The Auto Damper controls the fresh food temperature and the Freezer Temperature
Control guides the freezer temperature. The fresh food compartment temperature is maintained by a damper assembly located at the back of the temperature control housing. Changes in air temperature cause the damper door to open and close. A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the coldest position increases the flow of freezer air into the fresh food section. The freezer compartment temperature control warms at a faster rate and cools at a slower rate, increasing the compressor run time necessary to maintain a satisfied freezer temperature control.
Click Here=> Here is how to test a Maytag MSD2756GEW Auto Damper
There is always other possiilities but I see two other things that may cause this and that is the defrost heater with defrost Thermostat=> 61006199 Defrost Heater Assembly
I know this was long and possibly confusing but please ask if you should have questions or one on one assistance, Thanks, Sea Breeze
Sep 14, 2011 | Maytag MSD2756G Side by Side Refrigerator
Fridge side warm freezer still seems okay
frig side is warm due too no cold or air getting to fresh food side . i would ck for ice on the cold coil in freezer . this is most common .. mm
Oct 22, 2010 | Maytag MZD2766GES Side by Side...
Maytag MFF2258VEM French Door bottom freezer not cooling
Your model will and may take extensive diagnostics. You know there is no simple answer to this question and I will not guess. Do you have the sevice manual availible? I do if you need but from the length of your message it appears to me that you want and will need help. Let me know, Sea Breeze
Mar 12, 2010 | Refrigerators
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
Maytag bottom freezer Model MBF2254HEB not blowing cold air into freezer or fridge, blows warm air if blowing at all, starts and stops. Any suggestions? Possibly a reset button somewhere? Thanks - Kurt
Aug 29, 2009 | Refrigerators
Fridg is not working right
Aug 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Working fridge, warm freezer.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge doesnt stay cold
Aug 28, 2009 | Maytag MZD2766GES Side by Side...
Left door open while cleaning out refrigerator and top unit shut off freezer is still on what should I do
Aug 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
Fresh food refrigerator not cold, freezer OK. Air grills not blocked & coil at the base is clean. It has been 3 hours & no cold air circulating & is warm inside fresh food area. Motor shuts off. No manual...
Have you checked to see if the freezer fan is running? Have you tried turning the unit off and giving it a 48hour defrost with both doors open? this may fix it if there's ice in the fridge vents. Is there alot of frost on the back wall of the freezer? cheers
Mar 26, 2009 | Maytag MBB1954G Bottom Freezer...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
