Question about Lexmark X4690 Wireless InkJet Printer
Lexmark x4690 won't print
It does not read the amount of ink in the cartridges. I replaced the cartridges, but still not luck.
SOURCE: Lexmark P6250 black ink cartridge won t print
Write to Lexmark - you won't get any joy, but their reply might be interesting. I suspect that Lexmark builds a chip into their cartridges preventing it being refilled. When replying to me they did not admit this, but did not deny it, simply stating that their cartridges were designed for single use only. When I said that, apart from the cost, I wanted to minimise my impact on the environment by refilling cartridges, they pointed out their proud association with Planet Ark. I suspect that Planet Ark is happy to be an apologist for corporate vandals, and I seriously question their 'green' credentials. Order your next cartridges from Europe where the printer companies are not allowed to chip their products.
Posted on Sep 02, 2007
  • 6 Answers
SOURCE: lexmark x5495
Lexmark advertises the cartridges supplied with this printer as cart. #28 and #29. They claim these are nonrefillable. The refillable cartridges are #28a,29a, 34 and 35, the last two being the high yield carts. Make sure you have one of these.
Posted on Aug 08, 2008
  • 66 Answers
SOURCE: lexmark x 3650 change ink cartridge but it still gives a message(
Hi Glesam,
The X3650 uses the No. 37 tri-color cartridge, i.e. 3 colors in 1 cartridge. Unfortunately, when one color runs out, the cartridge has to be replaced. When you change printer, you might want to consider a printer that uses at least 4 separate ink cartridges (black, cyan, magenta, yellow). This way you need to replace only the cartridge that runs out.
Rgds
S88
Posted on Dec 22, 2008
dawson57
  • 25 Answers
SOURCE: I replaced a new lexmark 23 print cartridge in my X4530 printer.
This happens from time to time. I have bought new 22 & 23 cartridges for my Lex. x3350 before with "flawed" contacts. Either return it for refund or buy a new one. Thw next working one you get, try re filling it. I get mine refilled at Walgreens. Cost for me in Texas is $10 for black and 15 for color. I refill them 4 times before I replace with new. Saved me a ton of money.
Posted on Jul 01, 2009
  • 413 Answers
SOURCE: Lexmark x4650 says "print cartridge missing" but just replaced.
CLick on Start, printers and faxes, right click on your printer icon, click on properties.
There should be a tick box to allow you to reset the cartridges to new....
Posted on Jul 02, 2009
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
I have a Lexmark x4690 and the printer keeps telling me I have an alignment problem. I say ok to doing the alignment but when the paper feeds through there is no ink on the page. Also, if I try to print...
The error could be due to the cartridges in the printer. Please follow steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier. Check the encoder strip (transparent strip behind the cartridge carrier) and make sure it is not unseated from its position.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power outlet to reset it.
6. When the printer turns on, check for any errors. If alignment error is displayed on the screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 10, 2011 | Lexmark X4690 Wireless InkJet Printer
How do I reset a refilled printer cartridge for a Lexmark X4650?
They are not resettable. This is one of the downsides to using refilled cartridges for this style cartridge. You should be able to tell the printer to ignore the ink levels and just print until it runs out of ink.
Jun 09, 2010 | Lexmark X4690 Wireless InkJet Printer
Lexmark printer x4690 says incorrect ink cartridge
1.check the instruction set here at the Lexmark site:
http://support.lexmark.com/index?page=content&id=HO3394&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X4690&searchid=1271735414583
Apr 20, 2010 | Lexmark X4690 Wireless InkJet Printer
Are the ink cartridges interchangable between the lexmark 4650 and the 4690? They certainly appear identical in every aspect.
Hello. The only common cartridge the X4650 and the X4690 uses is the #31 photo color print cartridge. Other cartridges for the printers are non-interchangeable. For your reference, you can click on this links to the Lexmark website. http://bit.ly/asi8dB and http://bit.ly/bvNeOa . First link shows you compatible cartridges for Lexmark X4650 and the second link is for Lexmark X4690. Hope this helps.
Mar 14, 2010 | Lexmark X4690 Wireless InkJet Printer
My Lexmark X4690 does not print properly. When i click print on any document the normal print window open but the print only loads 1% and then stops. The ink has been replaced recently but the computer...
The circuit of your cartridge is turned very weak.when the circuit turns weak the cartridge cannot help processing the print request.
To solve the issue you will have to insert another cartridge. Also try cleaning this cartridge and check if it works temporarily keep us updated.thanks for using fixya
Aug 28, 2009 | Lexmark X4690 Wireless InkJet Printer
Need help finding/changing ink for Lewmark x4690
http://downloads.lexmark.com/perl/downloads/downloads.cgi
will have the information you need. You can download a copy of the user manual for your printer.
Apr 27, 2009 | Lexmark Multifunction Wireless Printer/...
Lexmark X4690 Wireless InkJet Printer Logo
357 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
