Question about Toshiba Satellite A105 Notebook
Bios password The bios password was lost. No removable cmos battery. Do you know how I can dump the bios to reset pass?
    President:
  • 4,402 Answers
When I was doing some research on my mysterious BIOS password problem with my Toshiba.
Long story short, Toshiba is aware of the problem and has released version 2.20 of the BIOS software which states that they have "Added a workaround for a BIOS password anomaly."
I know this is not the forum to discuss this stuff but felt compelled after the many hours of frustration, diconnects and name-rank-and-serial-number talk with Toshiba Support and Toshiba Customer Service.
Bottom line is that depending on who you talk to a Toshiba or Toshiba Customer Service, they may or may not cover the up to $200 charge for removing a BIOS password..."Toshiba does not warranty software issues". If you have this problem just be persistant until you get ahold of someone who is aware that the problem is real and who will listen. And not that morron who told me "that there is no way a BIOS password can be set without someone setting it"...idiot. They will send an "exception code" to your service provider to do the work under warranty...I mean how can they not if they're aware the problem exist and post a fix on their own website.
I just got my lab top back from my Service Provider for the second time for this problem so I don't have many hours running it to see if it happens again...I've got my fingers crossed. The first time was in July '06 and the updated software didn't come out until Sept'06. So although Toshiba gave me an exception to remove the BIOS password, the software was still corrupt and it happened again in Nov '06.
Posted on Dec 17, 2007
BIO PASS WORD
Reset BIOS password, it can be done in two ways
Manual
Open the cover under laptop, remove the CMOS battery about 7 seconds, then plug it back. Turn on laptop, BIOS password will be lost. Perform setting date, time, etc.
Online (conditions: the laptop can desktop access)
Toshiba gives services, online flash BIOS. Download and install software ACPI Flash BIOS, according to model of laptop.
Example: Toshiba Satellite L305-SP6983R, software version: ACPI Flash BIOS version 2.20 for Satellite/Satellite Pro L300/L305/L350/L355
Nov 17, 2011 | Toshiba Satellite Laptop L655S5150
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Toshiba (K000002020) Motherboard
Intel bios supervisior pass reset with open system case
BIOS Password is stored in CMOS and retained by power provided by the CMOS (Coin-cell) Battery.
To Reset the BIOS Password, Remove the CMOS (Coin-cell) Battery from the motherboard for five minutes and restart the system. This will load the factory default settings and the password would be gone. Re-install the battery after the password is rest.
GoodLuck!
CreativeTECH
May 23, 2011 | Intel D945GCCR Motherboard
Blue bios password request. cannot get passed.
If you've already tried to get past the password 3 times and got it wrong each time, chances are you might have lost all the data on the hard drive.
Easiest way to get past the password is to take out the cmos battery and hold the start button down for at least 30 seconds (make sure battery is removed on a laptop and/or power is disconnected.)
When you restart the computer you'll get an error message. Just load defaults and it should be fine. You'll also need to reset the clock.
Dec 22, 2010 | Computers & Internet
HOW DO I RESET THE BIOS PASS WORD ON A TOSHIBA LAPTOP L355
Hi if you want reset bios password ( asume you forget it) You need reset bios find reset CMOS jumper or take out battery for few sec. All settings in BIOS will be reset. Let me know if you need more help
Aug 25, 2010 | Toshiba Satellite L355-S7811 Notebook
PASS BIOS ACER 2930 ASPIRE
Hi the only possible way to reset the password in the BIOS is to reset the CMOS battery. It is located in one of the panel below the sys (you must have proper expertise to do this) towards the right hand side. The battery is set on a jumper You first need to disconnect all power source i.e adaptor and battery. than remove the panels to try and locate the CMOS Battery. Remember not to tuch anything else or connect any of the cables any where else it may cause a problem for the sys and you. Once the CMOS battery is reset the BIOS password will have gone.
All the best
Feb 09, 2010 | Acer Aspire 2930-4661 Notebook
Forgot password for bios setting
For this issue if you need to fix it with your self you need to follow the instruction from me. First you need to open your unit. Locate where the CMOS battery located.
The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is.
If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
Oct 08, 2009 | MSI K8MM-V Motherboard
How to remove cmos/bios password ?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
Where is Cmos Clear jumper on motherboard to clear Bios password.
If you can't find the jumper, just remove the CMOS battery wait for 1/2 + hour and the re-insert the battery. This will reset the BIOS back to the default settings and you then need to set the Time & Date.
It may not remove the BIOS password if the laptop stores the password on an EEPROM chip.
Apr 16, 2009 | Acer Computers & Internet
Dell latitude d820 can't get intothe bios set up screen
The BIOS password is stored in CMOS memory which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine.
Hope you find this information usefull.
your feedback is appreciated.
Askari :)
Mar 27, 2009 | Dell Latitude D820 Notebook
Toshiba Satellite A105 Notebook Logo
156 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
