Question about Sony VAIO VGN-NR498E/S Notebook PC
Battery Problem My laptop is Sony Vaio VGN-NR498E It's all original and worked good until recently. Couple days ago, I set up new windows (changed from Vista Home Premium to Windows 7 Ultimate). Now, there's always an announcement that THE BATTERY IS NOT COMPATIBLE. I cannot use the battery. PLEASE HELP!!!
    Problem Solver:
  • 19 Answers
Thats small problem..there is nothing to fear about .....U Just need to Update the Bios...Update the Bios...visit the website of ur laptop producer and check for latest bios update..
Posted on Sep 27, 2009
Testimonial: "Thanks, I'm trying and I'll reply you later when it finishes."
    Novelist:
  • 192 Answers
This is due to the compatibility issue of the Operating Syste with the ISB Utility that is installed in the Computer. It is required to stop this program from starting automatically to fix the issue.
  1. Turn off the computer and remove the battery.
  2. Make sure only the AC adapter is connected and turn on the computer.
  3. Click the Start button, click All Programs , click Accessories , and then click Run .
  4. In the Run window, type MSCONFIG and then press the Enter key.
  5. In the System Configuration window, click the Startup tab.
  6. On the Startup tab, click to uncheck the box in front of ISB Utility . LoadImage('png61194.png','Block BorderSolid','','','ISB Utility')
  7. Click the OK button.
  8. In the System Configuration window, click the Restart button. LoadImage('png61195.png','Block BorderSolid','','','System Configuration - Restart')
  9. Turn off the computer, reconnect the battery and turn the computer back on.
Please try this steps....
Best of luck!!!
    Posted on Sep 19, 2010
    3 Suggested Answers
    • 16 Answers
    SOURCE: sony vaio
    bodol kuwi mas..tuku wae sing seri anyar...aja pelit knapa
    Posted on Aug 11, 2009
    • 56 Answers
    SOURCE: sony vaio won't charge new battery
    i believe it is a charger issue not a battery issue replace your charger
    Posted on Apr 09, 2010
    Laptop: Sony Vaio Serial Tag: C3LRMD7Q Model: PCG7133L Need information for recovery disks for the foremention laptop. The OS is Windows VISTA Home Premiun.
    The VAIO Model VGN-NR498E/S is shipped with Recovery partition in the hard drive. It is required to create the recovery discs as soon as you get the notebook. Using either recovery discs or the recovery center you can reinstall the preinstalled OS in the computer. But, it depends if you has changed the preinstalled OS, the recovery partition will be erased and no longer be accessible.
    However, in your case, if you not made any changes to the preinstalled OS, restart the computer and press and hold the F10 key. this will launch the recovery tools. On the next screen, press Enter key. Then you will be able to view options such as "Restore C Drive", "System Restore" etc. There select "Restore C Drive" to reinstall the preinstalled Vista OS in the Computer.
    If you have changed the preinstalled OS in the computer, then it is requires to purchase the recovery discs from Sony's parts center:
    https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=partSearch&searchText=Y8318272A&sessionId=pfBoWO6gh7vj_fseXl4oiMI
    The above part is no longer available with them However, you can use the part #Y8318272A to search for the recovery discs with online retailers and others.
    Thanks!!!!
    Dec 16, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
    My Sony Vaio VGN-NR498E laptop with Windows Vista recently had some issues. The light in the screen seems to have went out. If you hold a lamp up to the screen you can make out the background of the screen...
    A dim laptop lcd screen is either the result of 1) a faulty inverter which is a separate piece from the lcd screen or 2) a burned out backlight which is part of the lcd screen. In the majority of instances, the inverter is the cause of the problem and not the backlight as most people tend to assume and therefore does not require the purchase of a lcd screen.
    I have done some research and it seems you can fetch a new inverter for around $59.00
    Nov 08, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
    Sony vaio won't charge new battery
    Apr 08, 2010 | Sony VAIO VGN-CR410E/W Laptop
    I lost all data from my sony vaio vgn-nr498e even original windows(home premium) and recovery partition.how can i recover it if i am using another windows at present
    You will need a good disk recovery software. These utilities do come at a price. Email disk recovery experts such as Recover Data or Sony Vaio data recovery if they can help you.
    Please share your feedback to help others.
    Feb 07, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
    My laptop left mouse button has stopped working
    Common hardware problem. The correct solution is a replacement tracker pad and mouse, however you may be able to get the problem fixed by cleaning under the pad. Either way it requires taking the laptop apart.
    WildeFalcon
    Feb 06, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
    Sony vaio
    Aug 11, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
    Compatability
    check with sony
    Aug 28, 2017 | Sony Cameras
    I want to install win xp on sony vgn-nr498e but i cant do it
    you can,t b,coz the system is based on vista thats y u,ve to reboot with vista and can,t b installed xp pro ok-doky
    Feb 09, 2009 | Sony VGN-NR498E/W 15.4" VAIO NR Series...
    Sony VAIO VGN-NR498E/S Notebook PC Logo
    466 people viewed this question
    Top Sony Computers & Internet Experts
    Alun Cox
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
