Question about HP OfficeJet G85 All-In-One InkJet Printer
Office jet g85
I have an error message in scanner window that reads, "scanner error, turn power off then on again"
  • jjandrositz Dec 28, 2007
    when scanning or copying (haven't tried faxing) I can get one copy or one scan. When the copy/scan arm begins the next scan or copy the message appears noting copy/scan failure and stating that the printer should be turned off then on again. Upon following the instructions (off then on) I can again make one more copy or scan (or a scan preview). I have taken the printer apart to include the scan/copy arm. I cleaned as much as possible, blew out any particles and turned the belt over...all to no avail : - (
    Problem Solver:
  • 17 Answers
Power on the printer, wait around 15 seconds until the bulb assembly moves a bit to the left and the light goes on, then immediately power off.
Repeat the process around 15 times (or more) until the assembly has moved all the way to the left of the glass, and is located directly beneath the small glass on the left.
Remove the single screw that holds down the small glass.
Carefully remove the grey frame around the small glass.
Carefully remove the small glass.
Using a dry Q-tip, carefully insert it into the slot (to the left of the bulb) and clean the mirror. I found mine was coated with a layer of film, as if grease had accumulated over time.
Put everything back together.
Turn on the printer.
Posted on Feb 04, 2008
G85 desk office jet
According to Intuit it may due to inappropriate printer driver settings, for resolve this issue follow these tutorial steps Problem Printing Transactions to HP Printer and if not have enough technical knowledge or need any guidance during this process follow Intuit Support Number .
Feb 01, 2014 | Intuit Computers & Internet
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
Scanner Error Power Turn off than on
If you are get that error message than unplug the power cord, and than press Poun and Number 6 Keys together on the keypab of the printer. While these keys are pressed and hold, than at the same time plugged in the power cord and dont release the two buttons.
After say 30 second you will get a new message on the screen of the printer.
All of the above steps actually reset the printer. I hope this will work.
Regards,
Lalit
Aug 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet g85 All-in-One error
Dec 17, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
