Question about Frigidaire FRS26R4A Side by Side Refrigerator
Refrigerator freezes everything even on low setting
  • Frigidaire Master
  • 909 Answers
Is it a single or double door? Assuming it is a double door. Normally the upper grade models have an auger motor that opens and closes electronically depending on temperature demand. This auger situated at the top LSD of the fridge normally freezes up due to various reasons. Most common is, product is placed to close to outlet which in turn creates a blow back effect and seizes the mechanism. Need to defrost fridge section for about 2 hours for ice to melt. Retry.
If it is a single door, your thermostat needs replacement. I'm taking it you have adjusted the settings higher(not so cold) but still not correct.
Posted on Sep 27, 2009
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
Why does Our refrigerator keeps freezing everything? Even the food in the drawers are frozen. Why is that?
Check the cold control thermostat setting maybe you set it to max. put both controls on middle of whatever numbers you have on them and if its already on middle or at minimum setting still it freezing everything you need to replace to Cold Controller Thermostat
Aug 23, 2014 | Jenn-Air JCD2295HES Side by Side...
I have a true double door commercial refrigerator. it stay below freezing even though I set the temperature very low. it is freezing everything.
thermostats on those things are notoriously bad. probably a bad thermostat. should have numbers 1 - 9 and usually set on 5
Aug 18, 2013 | True Refrigerators
A while back the refrigerator was freezing everything even though it was set on low. Even the veggies in the veggies drawers would freeze. Now, it stopped doing that but once in a while it will start...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 26, 2011 | Magic Chef CTB1722 Top Freezer...
I have the Magic chef 18EYW-2 1.7 refrigerator and everything is being froze when set on 1. I have even tried setting on the preferred setting. Everything is still frozen. HELP! Thanks.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 05, 2011 | Refrigerators
Miele fridge too cold
Hi I have the same problem...did you find the solution?
Jul 18, 2009 | Refrigerators
The refrigerator is freezing everything, even when temp is adjust
Leads me to believe the thermostat is not working. See if you can find the model number located on the bottom frame near floor behind fresh food section door and I will be able to help you better, Thanks, Sea Breeze
Mar 21, 2009 | Refrigerators
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
182 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
