Question about HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet g85 All-in-One error
I have an error message in scanner window that reads, "scanner error, turn power off then on again"
  • jjandrositz Dec 28, 2007
    When scanning or copying (haven't tried faxing) I can get one copy or
    one scan. When the copy/scan arm begins the next scan or copy the
    message appears noting copy/scan failure and stating that the printer
    should be turned off then on again. Upon following the instructions
    (off then on) I can again make one more copy or scan (or a scan
    preview). I have taken the printer apart to include the scan/copy
    arm. I cleaned as much as possible, blew out any particles and turned
    the belt over...all to no avail : - (
  • Anonymous Jan 22, 2008
    When copying I can get one copy or one scan. When the copy/scan arm begins the next scan or copy the message appears noting copy/scan failure and stating that the printer should be turned off then on again. Upon following the instructions (off then on) I can again make one more copy or scan (or a scan preview).
    Problem Solver:
  • 17 Answers
Power on the printer, wait around 15 seconds until the bulb assembly moves a bit to the left and the light goes on, then immediately power off.
Repeat the process around 15 times (or more) until the assembly has moved all the way to the left of the glass, and is located directly beneath the small glass on the left.
Remove the single screw that holds down the small glass.
Carefully remove the grey frame around the small glass.
Carefully remove the small glass.
Using a dry Q-tip, carefully insert it into the slot (to the left of the bulb) and clean the mirror. I found mine was coated with a layer of film, as if grease had accumulated over time.
Put everything back together.
Turn on the printer.
Posted on Feb 04, 2008
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
I just installed the software for my printer officejet g85. I tried to scan my first picture and it says scanning error... scanner cannot connect with pc. What does that mean?
Means scanner is not connected to the PC in the proper way.
check the port you are useing to plug the cable in the PC...
or try it by changing the cabl...
regards,
Dec 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Scanner FailureTurn power off then on again Message Window pops up continuously
Below is the document that i want you to follow.
CLICK HERE ===>> DOCUMENT
Pleae let me know the result after performing the steps.
thank you so much.
adonscott
Jun 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp officejet g85 - problem
hi,
unplug the telephone cable from the back of the printer and then turn off th printer.
turn it on after few seconds. check whether you have the error message and if not plug the telephone cable back to the printer.
if it is not working please contact me again.
thank you
agnel
Mar 14, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Office jet g85
Dec 17, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
142 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
