Question about Razer RZ01050300 Mouse
Middle button not functioning - the middle button sensitivity has suddenly dropped and become very weak. I have to press very very hard
  • 44 Answers
Hate to tell you but it is a common thing that goes wrong with Razers, inside the mouse there is a rod that is connected to the middle mouse button, this is also connected to the engine that tell the mouse what you are doing, after to much use this engine simples dies and forces you to buy another mouse
Posted on Sep 27, 2009
Acer laptop beeps twice with hard drive in, says there is no bootable device. it was recently dropped
HARDDRIVES ARE SENSITIVE FOR SUDDENLY MOVES LIKE FALLS.YOUR HARDDRIVE IS PROBERLY BROOKEN.
Aug 13, 2013 | Computers & Internet
I dropped my LG GT350 phone, it can be switched on and fully function, but the touch screen display is not showing. It can still be pressed and a dim blue back-light is on but nothing can be seen
The LCD screen may have been damanged, visit your celphone technician or phone provider to have it checked depending on the impact of how hard you dropped it, touch screen phones are very sensitive if you dropped it really bad the technitian may have to replace the screen.
Jul 07, 2011 | LG GT350 Cell Phone
Hi, my KX lcd display suddenly went black when I turned on the power. I bought my unit last December 2010. I'm pretty sure it was not dropped or bumped hard to cause any malfunctions. Batteries are...
When you say you are "pretty sure it was not dropped or bumped hard", a red flag goes up and tells me that it probably was. This could certainly cause a connection to become loose and cause the problem. But, lucky you, it's being fixed under the warranty!
Jul 05, 2011 | Cameras
Buttons on remote must be pressed hard to work>
There are a number of problems that could cause the issue you describe. A weak battery could be the culprit. If changing the battery does not resolve the issue then some type of substance may be on the contacts of the buttons. The keypad of your remote is a series of simple switches that when pressed function according to the programming of the remote. Spilling something on the remote and then having it dry up could leave a film on the switches that would make it difficult for the contacts to close. By pressing harder you are forcing enough of the switch to make contact that it will finally function. If the remote is in a room where people smoke this can also leave a film on the contacts and subsequently make it necessary for you to press the keys real hard to make them work. Finally, the keys themselves will wear out over time, and it will then become necessary for you to press them real hard before they will function properly.
If changing the battery/ies does not resolve the issue then your choice is either attempting to clean the remote, or replace it. Many remotes are difficult at best to take apart. The keys and switches are quite small and can be very difficult to try and clean without damaging them. If your remote uses the micro switches instead of the switch array it is impossible to open them up to try and clean them out. At this point you would be better off checking with your local electronic repair center to find out how much a replacement remote would cost. Depending on the age of the remote you might not be able to get a replacement. You would then either have to put up with pressing down hard, or look at possibly replacing it with one of the programmable remotes that are now available. Should you choose this route check with either the manufacturer's website, or your local store. to ensure that the universal remote will indeed properly control all aspects of the unit you want to control.
May 15, 2011 | RCA Televison & Video
All of a sudden, my gateway laptop nv52 screen dims on AC and brightens on battery power. It must be a key combination because I suspect my cat walked across the keyboard.
Try this,press function(Fn) and the power up button/down button. that will fine tune the middle setting your laptop. the middle setting is one of 3 settings, you need to press function and f8 to switch between lowest, middle, and high. the middle setting can be any setting you like and will be the default setting when you use your computer with a chord or without it.
Thank You
Jan 04, 2011 | Gateway Computers & Internet
My MacBook trackpad button has no effect when I press it at the bottom in the middle, the normal place where my finger falls on it. I have to press it on the left or right sides or the side towards the...
I used to drop drags and other motions on my White early 2009 MB. The "origami" solution for me was the answer. Place folded thick paper folded say 3 times to the size of a nickel to quarter in the battery compartment on the round area opposite the trackpad. Replace the battery and you will find the pad much more sensitive. Almost too sensitive, adjust the thickness. The battery presses it up on the contact. -Ken
Jul 07, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Sometimes middle of process, it suddenly stop. and i try to trun off and press start button again, but nothing happen.normally if i press start and it shows green light but it didn'nt. it seems start...
IT SEEMS TO ME LIKE THIS SWITCH HAS WEAK CONTACTS
OR WEAK TERMINALS .
THE SIMPLE CASE IS USING SMALL PLAYER AND TO SURE THE TERMINALS IN GOOD CONDITIONS
Jun 18, 2009 | AEG Washing Machines
Magnifier doesn't work
Try going to Control Panel and click on the mouse icon. Then the mouse properties will appear showing the mouse. In the left column,move your cursor over the right side button click on the drop down and select magnify. Hopefully it will now work.
I had to move the magnify function to the left button because it was to sensitive on the right.
Nov 27, 2008 | Microsoft Wireless Laser Mouse 5000
V3 fx steering wheel for PS2
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 Here are all of the instructions enjoy. clip_image001.gif
To adjust the V3 Racing Wheel 2's sensitivity follow the instructions below. ( 3 preset sensitivity selections )
1. Press and hold the SET button for about 1 second to enter the "FUNCTION SETUP MODE", the MODE LED indicator will start blinking and two "beeps" will be heard.
2. Press the direction on the digital/analog directional pad and SELECT button that corresponds to the setting you desire. Directional pad UP and SELECT will give you high sensitivity. Directional pad LEFT/RIGHT and SELECT will give you medium sensitivity. Directional pad DOWN and SELECT will give you low sensitivity.
3. After selecting one of the above sensitivity options you will hear 2 "beeps" letting you know that the wheel has been programmed. For Customizable Sensitivity follow the directions below.
2. Rotate (either left or right with the wheel ) and then hold the wheel to the specific angle desired.
3. Press the SET button again, two "beeps" will sound to indicate the completion of the setting
To reset the the V3 Racing Wheel 2 to it's factory default settings press and hold START, L1 and L2 buttons in until you here two "beeps".
To change between Digital and Analog modes follow the directions below.
2. Press the SQUARE and SELECT buttons to set the wheel to DIGITAL, or the O and SELECT buttons for ANALOG. Two beeps will sound and the MODE LED will stop blinking letting you know that the mode has been selected.
By default GRAN TURISMO 3 A-SPEC uses the X and Square button for gas and brake. To reassign these functions to the pedals on your racing wheel:
1. Go to the options menu in Gran Turismo.
2. Select key configuration. (The picture of the Game Pad.)
3. Scroll down to Acceleration
4. Press Right on the D-pad (11x) until Analog Up is selected for the Right Analog Stick
5. Now go down to Brakes
6. Press Right on the D-pad (10x) until Analog Down is selected for the Right Analog Stick.
7. Press the X Button to confirm your changes and then press the Triangle button to return to the main menu
8. The gas and brake functions for the game will now be set to pedals on your wheel.
Sep 10, 2008 | Cables Unlimited InterAct Racing Wheel V3...
Razer RZ01050300 Mouse Logo
512 people viewed this question
Top Razer Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Avishek Samaddar
Avishek Samaddar
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
