Question about GPX MW3837 MP3 Player
Need help bad
I have been on computer all day and cannott download anything on my mp3 player. it sais error occured media write restricted. its brand new and i have tried everything to get the dang thing to work.
If you have moved your music files from their original location you'll have to move them back for them to download.
Posted on Dec 25, 2007
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the smpk4083 mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
Whenever i try to play a song on my phillips gogear vibe mp3 player it sais "file format not supported' and they are mp3 files.What gives?
"File format not supported" means that the song that you've downloaded into your MP3 player is NOT an .MP3 file format. For each MP3 player have their own supported file formats. You need to check the manual of your MP3 player to see what are the supported sound file formats (i.e. .mp3, .wma, .mp4). Then check the file format of the songs that are saved in your player.
If the songs are supported but you're still getting the error message, try to delete all the songs and then download the songs again and save it into your player. If the same problem occur, then it may need a firmware upgrade or reformat.
Thank you and good luck!
Oct 31, 2010 | Philips GOGEAR SA6045 MP3 Player
I have a 2gb mp3 player i upload songs from my computer and then go to listen to them and nothing plays or works.the green light will be on and when i press the play button it blinks three times and still...
Some mp3 players will not play songs if you just drag and drop stuff on them. You will need to sync your music using some kind of software(ex:Itunes for Apple Ipods and Iphones). If you can just let me know the brand and model of your mp3 player, I can help you find the appropriate software to sync it with your computer.
Dec 02, 2009 | Audio Players & Recorders
Can't download videos to PHILIPS GoGear 2GB MP3.
first off get the arcsoft media converter 3, then drag and drop the videos you want to get on your mp3 player into the program, after it converts it it loads them onto your mp3 player as long as its connected, this program will also allow you to download youtube videos and put them on your mp3 player too
Apr 10, 2009 | Philips GoGear SA3125/37 MP3 Player
My mp3 player won't do anything!!
Hello there,
It is unlikely that the player is dead but the Usb cable or USB/charging port or the battery is dead. If the player is under warranty you can demand for a replacement. Otherwise check if a replacement usb cable would fix the issue. Otherwise its going to cost you around $30 for repairs.
Feb 15, 2009 | Philips GOGEAR SA6045 MP3 Player
My iLO MP3 wont download anymore
well i usly go to my computer and open file g then look for music file and drag my music in to that file which i think you find easier than trying to under stand the technoligy
Feb 09, 2008 | Apple iPod shuffle MP3 Player
Wont download songs
Look at this article, this may help
Jul 27, 2007 | SanDisk Sansa e270 MP3 Player
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
