Intel Pentium III Socket-370 CPU to Slot-1 Motherboard Adapter with Jumper Setting CPU Cooling Kit
Problem for Intel Pentium III Socket-370 CPU to Slot-1 Motherboard...
Converting airshocks into regular shocks
By djeweje on Dec 17, 2007
I have a 1989 Lincoln Mach 7 with air shocks. They have gone out and wewant to convert it into regular shocks. What do I have to do?
Solution #1
posted on Apr 04, 2009
Not Rated)
allenry
Rank: Apprentice
Rating: 0%, 0 votes
yes i have a 91 olds toronado want to convert from air shocks on rear to regular can that be done if so where do i find them thx allen
Was this helpful?
Yes
No
Solution #2
posted on Nov 26, 2008
Not Rated)
darknight910
Rank: Apprentice
Rating: 0%, 0 votes
I know full well this question is over 1 year old.
The Lincoln Mach 7 uses air bags/bladders that are springs and shocks combined.
The only REAL repair is to install new ones. That being said, make sure the bladder is the true leak.
NOTE: If you have to raise the car, be sure to disable the level ride system,usually has switch in trunk on left side. Consult your owners manual.
Leaks at the line seals/fittings are very ,very common. The bladders usually crack or rip inside the folds.
Replacement bladders can be had as a kit from your Ford dealer.
Once you have replaced bad bladder(s) spray all conceivable air lines and connections with soapy water and check for leaks. NOTHING is worse than replacing the bladders only to lose air after an overnight park.
Was this helpful?
Yes
No
Solution #3
posted on Apr 12, 2008
Not Rated)
BNUTZBCRAZY
Rank: Master
Rating: 88%, 49 votes
aaahhhh, yea if im not mistaken those are the ones that are controlled by computer? my guess would be to find some from maybe a crown victoria and see if they are compatable. or call a autoparts store and see if they carry a non-air version for that car. most of the time, parts on the same make and year of a car will be interchangeable. if they are built around the same frame. like the alternator out of a crown vic would probably be the same one thats in your car for example. but im positive you should be able to get non-air shocks for it, or even call ford and ask what shock were compatable with the mark7. i see those cars around my town and they look like they have been lowered cause the shocks and or the controlling computer have gone bad. i hope this helps but try to see about ones off of a 89 crown vic. i bet they have the same bolt patterns
Was this helpful?
Yes
No
Popular Solutions for Intel Pentium III Socket-370
Questions and Unsolved Problems for Intel Pentium III Socket-370
Do you recommend Intel Pentium III Socket-370 CPU to Slot-1 Motherboard Adapter with Jumper Setting CPU Cooling Kit?
Answer
Answer
My eMachine T5026 computer was sitting idle for over 24 hrs. When I wanted to use it I noticed toe... (More)
Answer
I have a FMI, GL-4000e fireplace that has a hard time starting, but once it does it will burn for... (More)
Answer
I have just purchased a 2000 Micra without the hand book. Any iders where i can get one for free or... (More)
Answer
Is there any fix for a Sunbeam Brita water filter/cooler mod. WF5900 ? Everything works except the... (More)
Answer
Re: remove the heat sink fan wiring from a Gateway MX6920 laptop. I've found the disassembly process... (More)
Describe your System Cooling problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top System Cooling Experts
Top Computer & Laptop Repairmen
in , MD
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
