Question about Dishwashers
I put detergant accidently in salt section dishwasher
  • 23 Answers
The Bosch book says running the dishwasher with detergent in the salt compartment will "destroy" the softening apparatus.
Posted on May 02, 2010
    Problem Solver:
  • 17 Answers
If yo run the dishwasher a few times it should flush it through
Posted on Sep 27, 2009
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
Have lost my manual. Cannot remember when putting in the dishwasher salt, should the cap be showing the red spot? Not sure at what point you put in the salt? Thanks for your help
Not sure if you are referring to the dishwasher detergent or the rinse-aid.
The two items are mentioned on pages 13 and 14 of the user guide for GU2400 model.
Hope this helps. Cannot find any mention of salts or cap red spot.
Jun 28, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
What kind of salt do I buy for use in the Danby DW?
Well Dishwasher salt is a particular grade of sodium chloride salt, and is used for recharging the built-in ion-exchange resins of the water softener in dishwashers that have a built-in water softener. The salt particles are larger than the size of table salt particles, and dissolves slowly enough that it will not clog the softener unit. This salt does not have added iodide salts, and it should have minimal amounts of iron and manganese salts. Some dishwasher detergents are marketed as not needing dishwasher salts. These detergents use higher levels of phosphate that increases the solubility of hard water ions. Never use table salt or detergent in the salt compartment of your dishwasher as this will damage your water softener unit. You can purchase the dishwasher salt from the below link -
http://www.mysupermarket.co.uk/grocery-categories/Dishwasher_Salt_In_Tesco.html
Good Luck!!
Thanks
Jan 07, 2010 | Danby 17 in. DDW1802W Designer Series...
I put powder detergent in salt compartment in my dishwasher by mistake. What do I do next?
Just flush it out by pouring plenty of water into the receptacle. You don't have to get every last trace out. Make sure to wear rubber gloves and possibly eye protection as the powder is caustic and so you need to avoid skin and eye splashes.
You could alternatively leave the salt chamber cap off and run the dishwasher empty for a couple of cycles; that will allow the powder to dissolve without any chance of you getting splashes on your skin.
Nov 13, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
A BLOND MOMENT!!
Run it and run it and run it.
The salt will melt.
Use hot water fill.
Feb 27, 2009 | Kenmore 17439 Built-in Dishwasher
Dishwasher : accidentially put detergent(soap) into the salt compartment !!
You should be able to run it threw and not have an issue.
Just dont add anything else.
Sep 11, 2008 | Neff 24 in. S5409X0 Built-in Dishwasher
LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
Jun 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
194 people viewed this question
Top Dishwashers Experts
