Grundig telepilot 160c not working
Second hand 2 y.o Grundig Tele Pilot 160C remote control not working properly. It only works sometimes (rarely!) it almost seems that it's got its own mind! Unsure whether this is due to the 160C RC breaking down or problem of actual TV or some problem with coding/locking. Any help would be appreciated!
SOURCE: gu15wdvdt tv .sky remote code
posted by mike 13 aug 2008
I have just had sky installed and the code for grundig gu15wdvdt is 1239
Posted on Aug 12, 2008
gcrcomputers
  • 170 Answers
SOURCE: I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
Posted on Mar 17, 2009
SOURCE: Tuning a Grundig Tele Pilot 750c Television
It might be an old hotel tv. Try this, it worked for me
http://www.tvtuning.co.uk/makes/grundig.htm
basically you hold the i button whilst turning on the tv.
ta
Posted on Jun 13, 2009
SOURCE: Need remote control code for ATT U-verse
I HAD THE SAME PROBLEM WITH A VIZIO VL260M. THE CODE 1343 WORKED FOR ME ALSO.
Posted on Nov 09, 2009
  • 5 Answers
SOURCE: 32" Sylvania TV/DVD won't work with my AT&T UVerse Remote
I bought a 32 inch sylvania LD320SSX TV/DVD and had trouble with a Media-Com remote. Finally got it to work using code 1864
Good Luck
Posted on Nov 30, 2009
Garmin fishfinder 160c sonar failure
Hi Lakshmaan:
The first thing I would check would be the electrical connections from the transducer, and the transducer wire.
Jun 07, 2016 | Garmin Color Fishfinder 160c
How to solve sonar failure(Showing on Display) in garmin 160c fishfinder.
I would guess that "sonar failure" would mean that no signal is being received from the transducer.
Trouble shoot accordingly.
Is vltage 110 or 220 volts
Would that not depend on which country you bought it and where you are trying to use ? Check the back of the Washing machine for voltage details.
the manual is attached. DAEWOO DW 160C Instruction Manual
Apr 27, 2016 | Washing Machines
HOW CAN I CKECK HOW LARGE IS THE FISH TO FISHFINDER 160C?
the bigger the icon the bigger the fish no fish finder can tell you how big a fish is
Apr 15, 2013 | Garmin Color Fishfinder 160c
Can I get an inboard transducer for my Garmon 160C fish finder?
Yes you can. You would need Garmin part #: 010-10224-00. You can order this part off the Garmin website if you do a search for 160 and look under the accessories.
Jun 16, 2010 | Garmin Color Fishfinder 160c
To wireup 160c Garmin fishfinder, there are seven clored wires. The book shows red and Yellow to hot. Black and blue to ground. Do the white, green and brown connect? Can the black and yellow be connected...
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Jun 14, 2009 | Garmin Color Fishfinder 160c
ta
Jan 07, 2009 | Grundig GF70-600 TV
Konica Minolta Zoom 160c won't turn on--lens stuck out and open
There is some kind of grit or something in the lens gearing mechanism, preventing its movement. Take it to a repair facility, or replace it.
Jul 26, 2017 | Konica Minolta Zoom 160C Date 35mm Point...
Televison & Video Logo
1,097 people viewed this question
Top Televison & Video Experts
Electro Med Services...
