Question about JVC Video Cameras
The model is mg50ek there is no picture when its
When its on, there is no picture and it gives this massge on the lcd caps is on (or remove the cap ) while the cap was already removed
  • 156 Answers
Need to check the iris unit(shutter in side the otical block).That you can check when you start the camere you here a click sound from the optical block.
is opening?if it is opening need to replace CCD base.
Posted on Sep 28, 2009
Samsung model no. LN 32A33OJ1D code. LN32A33OJ1DXZA wont turn on for nothing and someone try to charge me $500.00 to fix it need help !!
If I am corrct, It may just need a set of caps in the power supply, about $15 worth and may be 45 minutes of time,
see pictures here; http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20LN32A330/
Sounds like someone is ripping you off or never works on repairing TV before, jhe ust gives you high estimate and charge you alot just for the estimate alone. That kind of repair shop gives all repair shops bad name.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 14, 2011 | Samsung LN32A330 32 in. LCD TV
I get a black screen. i still have sound with no picture
Hello; If this is a 32" LCD, it is probably the same model in my older post. Always give your model number , so we know which set you have. John
Hello; This set uses a very poor design. They are stacking two 450 volt cap to get a 900 volt rating needed in this circuit. This practice was used decades ago, but only with VERY high quality caps that are closely matched ALONG with stabilization resistors to keep the voltage drop even between the 2 caps. Polaroid uses cheap unmatched caps and even WORSE no stabilization resistors. Shame on you Polariod. At least one cap is bad, but they MUST both be replaced with high quality MATCHED caps. There is an 80% chance that these are your problem, but with NO WARANTY. If you have no way of soldering and testing, send it to me with $38 to cover parts, testing caps and return shipping. You must call first 207 998 5687 est. No weekend hours, but OK 9-5 est. Good luck, John
Feb 04, 2011 | Polaroid Televison & Video
I got View Sonic VE710b and he do not show any picture after connecting with VGA cable , any solution ??? thanks in advance
The PC is OK when hooked up to another monitor?
This model and other VIEWSONIC are known to have bad caps with domed tops, also check the fuse as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VE710B/#!cpZZ1QQtppZZ20
Basic LCD monitor and LCD TV troubleshooting guide:
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 23, 2011 | ViewSonic VE710b 17" Flat Panel LCD...
I have a lg televison model # 42lg30-ua, i have sound but no picture, can you give me any suggestions?
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$???????
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and Good luck.
Kaufman605
Dec 12, 2010 | LG 42LG30 42 in. LCD HDTV
Tv cycles on and off repeatedly while plugged in.
Samsung caps
http://www.avforums.com/forums/attachments/lcd-televisions/128595d1247354171-samsung-40-lcd-one-year-old-beyond-repair-caps.jpg
Above should be a link to a picture of the caps if not google " Samsung power supply caps" and look for other images.
Hope this helps
Once the back cover is removed the caps are obvious to spot (especially with that picture I forwarded) you need to label and remove all the plugs - unscrew the board from the chassis so you can get to the solder side of the board.
Once there all that is required is to observe how the caps are placed in - and + side of caps and unsolder the old caps 10V 1000Uf and replace with new ones of higher value 16V 1000Uf
If your feeling adventurous do it yourself otherwise get quote from a reputable shop.
Also google "Samsung power supply capacitor replacement" and there may be step-by-step instructions with pix.
Oct 24, 2009 | Insignia NS-LCD37 37 in. LCD TV
My TV has been taking about 3 minutes to come on. Every now and then it it has pixels that freeze at a certain color and will clear up when i cycle the power. Is this possibly a power supply problem?
Samsung caps
Hope this helps
Oct 22, 2009 | Samsung LN-T4665F 46 in. LCD Television
Have sound but no picture
LG has a problem with bad electrolytic caps-remove cover look for swollen caps-replace all swollen caps
Sep 10, 2009 | LG 42LC2D 42 in. LCD HDTV
TV no longer comes on, blue light appears but no picture.
I fixed my problem for $3.44 at Radio Shack.
This is a common problem with this model.. go to you tube and search for polaroid 37 lcd repair, there is a video showing which Capacitors to replace. there are two, i bought 2 1000uF 35 watt/volt capacitors. you have to take the back panel of the TV off, remove the power supply board, and de-solder the two CAPS. install the two new CAPS, re-solder them, put the TV back together and enjoy. Radio Shack part #'s i used 272-1032.
Jul 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Video Cameras Logo
21 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
