Question about Nokia N72 Cellular Phone
My fone doesnt switch on its not working first it started this way that it used to keep on switching of and on all by itself than it went black and now it doesnt switch on
  • 438 Answers
Update ur firmware!!!!!
Posted on Sep 27, 2009
My x10 mini pro(sony) switch off and on by itself. Happens a few times per day, sometimes every 5 minutes
follow the steps:
1 - remove your SIM card from your phone.
2 - install and download the SE PC Companion 2.0 from the following link:
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pccompanion/xperiax10?cc=gb&lc=en
3 - click the start button in Suport Zone, then software Update.
4 - follow the steps of the installer.
5 - when finished reset the fone, and wait it to start.
6 - turn off your phone.
7 - insert again your SIM card.
8 - try to turn on the fone.
9 - when turned on, if it was without net signal, make a hard reset, holding the center button, and then press and hold the on/off button and wait it to vibrate.
10 - release the buttons, and wait.
Jun 05, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Coleman powermate compressor wont start. It has always ran fine. Went out and the tank has no pressure. Everything looks Ok, but it wont start. Doesnt even make a sound. There is power at the plug in. ...
Two main things to check are the motor circuit breaker and pressure switch. Without knowing your model number I don't know exactly where to tell you to look but somewhere on the electric motor, or plastic housing if it's remotely mounted, there should be a reset switch/button. They are usually red or white, sometimes black. Push it in and see if the motor works. If the breaker keeps popping off there is something making the motor work too hard like bad bearings in the motor or pump, piston/cylinder issues, etc. To check the pressure switch, unplug the cord or turn off the circuit breaker. Remove the cover on the pressure switch and find the wires from the cord and motor. You can jump them on the switch (black to black & white to white) or disconnect them and connect the two black wires together and two white wires together. Turn on the power and if the motor turns on it's the switch if not it may be that your motor is burnt up inside. Don't let it continue to run like this because it will overfill the tank to dangerous levels without the pressure switch wired in.
Jan 28, 2012 | Coleman Powermate 27 Gallon Air Compressor
My fone shows a black screen but i can still recieve calls
1. perhaps LCD is faulty
2. Software reload may also solve the problem if LCD is OK.
Aug 10, 2009 | Sony Ericsson W910i Cellular Phone
I phone Frozen or F'd?
try removing the battery,for 30 seconds , then replace , as u switch the fone on, plug it into the charger, this may help to re-boot your fone....
Jul 26, 2009 | Apple iPhone Smartphone
My n73 phone starts with installation and says application not supported everytime.
just update ur fone firmware OR hard format ur n73... by following method:
(note : b4 u do any of the above solution remove the password of memory card and also take the backup of ur memory card through Nokia pc suite not by using cardreaders....)
hard format :
remove memory card
switch off the fone
now press call key(green) + 3 + * key
keep on pressing all three keys and switch on the fone ... dont release the keys untill the fone boots on....
the fone settings will be restored to its default... also all d security codes of fone will be retored to defaults....
now ur problem is solved .... put ur memory card back.... n if it still asks for memory card unlock password ... then jus format it .....through fone..... it wont ask again.....
regards
Bhumit
Feb 03, 2009 | Nokia N73 Cellular Phone
I forgot the code
hi.. try nokia default code 12345. and if it doesnt work, try to reformat the fone by means of hard formating this is the way to hard format ur nokia n73. switch off the fone first... hold *+3+the answer key... hold it for up to 5 minutes without taking off ur hands,, then look for someone to help u switch on ur fone still dont take away ur hands from the key untilthe fone restarts... then u can now assign a new code for ur fone.. the default code is 12345.. hope this shld solve ur problem..thanks
Dec 22, 2008 | Nokia N73 Cellular Phone
Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Nov 05, 2008 | Nokia e65 Cellular Phone
Black Screen with horizontal lines
are u sure that ur not able to see the fone's stand by screen now?its totally black?are u sure that there's no problem with the screen itself,the care guys might have left the screen connection loose. other wise try one thing,Format ur fone. by pressing *#7370# u have press keys once wait for 5 seconds and press the left selectin key [where u get the YES option normally. the fone would restart and lets see are u able to go back on the screen. IF YES then u can set the Sleep mode to off cuz the sleep mode gets inititated after 20 minutes when u keep ur fone idle means u dont operate ur fone for atleast 20 minutes. BUT IN THIS CASE ULL LOSE ALL UR DATA INCLUDING CONTACTS AND MESSAGES ETC.IF U HAVENT TAKEN THE BACK UP EARLIER.so its totally upto u that u want to proceed with this step or u can again show ur fone to the nokia care guys. but they'll charge u cuz obviously after 2 years ur fone is out of warranty
Oct 05, 2008 | Nokia N73 Cellular Phone
It keeps switching itself off
it happened on my 6300 try removing your memory card (if any) then try turning in on..if that solves the problem then your memory card has a virus..try formatting them
Jul 10, 2008 | Nokia 6300 Cellular Phone
I forgot my security code n95
after months without my n95 and hours of scannin the internet i have found the solution to the lock code!!!! if u hav totaly 4goten the code u will need to flash the fone but...... if like me you are 100% sure the code u keep entering is correct then here is how to fix it!!! when changing your code u would have enterd a 6 digit code and re-enterd it to make sure it is correct yes? all went fine! wen entering it again it faild? thats where the problem lies. enter only the the 1st 5 digits of ur code and all should be fine!! if this fails turn off ur n95. press and hold the green key, the # key and the 3 key all at the same time as turning the fone on. keep them held untill the the lock code needs to b enterd. then repeat the 5 digits of ur code. unfortunatly u will loose contacts and msgs etc but it works! have fun!
Jun 19, 2008 | Nokia N95 Cellular Phone
Nokia N72 Cellular Phone Logo
27 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
