Question about Sony CLIE PEG-S360 Handheld
Possible dead battery, but I'd like to be sure
My Clie won't turn on, even when I plug it into the wall. Before I order a new battery for it, I'd like to be sure that the battery really is the problem. It seems a bit scary that it won't turn on even when it is plugged in, and I wonder if maybe that's an indication that it is more than a battery problem. Does anyone know if this sounds symptomatic of a dead battery or of something else?
  • 2 more comments
  • DerekDotH Dec 18, 2007
    That didn't seem to help, but I sure appreciate the suggestion! Any other thoughts?
  • Kate333 Feb 04, 2008
    I have the same problem. Mine is an older clie and the green light on the bottom won't come on like it normally does when you try to turn it on.
  • DennisBeach Feb 20, 2008
    I have exactly the same probelm.
    Is there a primary battery in here in addition to the rechargeable battery that is supposed to maintain functionality when the rechargeable voltage drops below some threshold?
  • Anonymous Jan 03, 2009
    Almost the same problem here. When I first got it, it would only turn on for a few seconds before automatically turning off. I figured the battery wasn't charged, so I charged it for a day or so. Then it seemed to work ok, so I put it away until Christmas (it was a Christmas present for myself, and I wanted to wait until Christmas before I actually used it. This was in early December).
    Then when I took it out on Christmas, it simply wouldn't work at all, just like everyone else is describing here. Absolutely nothing no matter what I do.
    President:
  • 4,402 Answers
This may sound silly, but make sure you didn't accidently spin the little wheel on the side thus, turning the screen down so low that it can no longer be seen.
I've had several co-workers do this and coming running to me to say they broke it... silly, but common.
Posted on Dec 17, 2007
Why wont it charge the battery when using the wall plug
Sir,
the charger must be tested, if it not giving the out put voltage, you have to change it, check the connecting point for possible loose contact or corrosion inside the jack.,clean it.
Dec 30, 2015 | Panasonic HC-V100M Digital Camcorder -...
Galaxy Samsung tab 10.1 won't turn on
you had to plug it in the charger for a while and then you hel the power button for more than a minute
if it not work hold power button and volume up for 20 sec.
Mar 22, 2013 | Tablets & eReaders
Asus wont turn on
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/laptop-ac-adapter/asus-ac-adapters.html
Nov 30, 2012 | ASUS K Computers & Internet
Won't turn on
possible battery problem. look at battery contacts. clean w/ pencil ereraser or small scraping devise.GENTLY, on battery and camera.
possible dead battery even if new.even if you buy a new battery, clean ththe contacts an battery and camera.
Sep 25, 2012 | Kodak EasyShare DX6490 Digital Camera
Display will not come on plugged in or not
The UPS needs to have a good DC Buss for it to work. Before you buy the new battery disconnect the battery & unplug it from the wall. Push the on button to reset the logic. You may see the display flash breifly. Install the new battery. Then plug in the UPS and turn it on and enjoy
Oct 20, 2011 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
My laptop shut off and will not come back on, any ideas? its a new battery, just 2 weeks old.
remove the battery and plug in the AC adapter only directly to a working wall outlet. If it still does not turn on, you likely have a failed system board. take it to a local repair place or call Dell for service.
Feb 17, 2010 | Dell Inspiron 1501 Notebook
The handphone is dead.
MAKE SURE YOU HAVE INSERTED THE BATTERIES PROPERLY AND THE RIGHT WAY,
EVEN WITH PHONES THERE SHOULD BE AN ICON SHOWING YOU THAT UNIT(S) ARE CHARGING.
FAILING THAT CHECK WITH ANOTHER SET OF BATTERIES AND REMEMBER TO CHECK THE FUSE IN THE PLUG
Jul 14, 2009 | AT&T 9353 Cordless Phone
Won't turn on
Your battery is dead. get a new battery
Aug 19, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Problem with Sony Clie - NX70V/E - battery
i just replaced the battery on my NX60. It was a very easy task. Look on the net for batteries. I found a battery for $18 plus S/H. It came with the special plastic screw driver and instructions. I just threw everything away or I would give you the company name. I found several. The instructions are easy. Simply remove the screw ofr the barrtey compartment and all the scrws holding on the back. Remove the back, carefully remove the battery, carefully replace the battery making sure you place the wires in the correct position. Replace the back and screw the thing together. You can also order a battery from Batteries Plus. The original battery in my machine was 1000 ma the newer batteries are 1200 ma. Good luck.
Mar 05, 2007 | Sony CLIE PEG-NX70V Handheld
Sony Clie sj33 battery
If you haven't already done so. Try resetting PDA in back, if that doesn't work go back to battery and verify connections are correct and check connection wires (they may be frayed or damaged). I'm not sure that will solve the problem, but it worths a shot.
Sep 19, 2005 | Sony CLIE PEG-SJ33 Handheld
Sony CLIE PEG-S360 Handheld Logo
98 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
