Question about Grundig GU19WDVDPCX 19 in. LCD TV
Dvd jammed within the dvd player
Hello there
i have a gurndig tv combo with the dvd player built in. but the dvd pleayer had one of my dvd jammed within the player. how do i remove it??
  • 54 Answers
There should be a small pin hole located on the front of the DVD tray. Gently push the end of a paper clip or something similar into the hole to release the tray.
Posted on Sep 27, 2009
How do you eject the DVD
I you can't do it with the Remote control, you might be able to do it on the TV itself.
I'm not positive about this, but there should be a button on the back outer-edge of the TV that may control the DVD player.
If not, here is a link to Download the manual. Scroll down & click on 'Guides + Info' and then the download link.
http://www.us-appliance.com/pledv1945a.html
PLEDV1945A Proscan 19 LED 720p HDTV with Built in DVD Player
Good luck.
Andrew
Feb 24, 2015 | Proscan 19 In. 720p LED HDTV/DVD Combo...
In the combo tv and vcr their is no pin hole near the dvd so how will I eject the cd
The best way, in my experience, is literally disassembly. Pull the back off of the television and be very aware of the different ribbons connecting PCB's. Note where everything was plugged in (take pictures if you must), and find where the built-in DVD player is mounted (should be attached to the back cover). Remove the player and disassemble. It's generally fairly intuitive. You should be able to reduce it into a pile of parts and get your DVD out!
Word to the wise: I'm an electronic service technician, and I have seen a good many of these built-in DVD players fail. Actually, they all tend to fail within a year. They are also 30.00 units. No 30.00 unit has ever been even close to a good piece of equipment. That said, don't replace the internal DVD drive. Just buy a component player.
May 14, 2011 | Magnavox 32MD359B 32 in. TV
I have a philips universal remote and i need the code for my tv which is a sv2000 with the dvd player built in
Hello crystal and welcome to FixYa. I think you were searching for the remote codes for a SV2000 TV/DVD Combo. Generally speaking TV/DVD Combos do not have a traditional codeset but instead use a DVD one instead. Follow these steps below.
Search the TV codes Using AV1 or AV2
Press and hold Mute and Select for two blinks
Enter 9 11
Enter 2
Press and release Volume Up
Press and release Channel Up until you hear the volume change
Next after hearing the volume change press Select to lock in the code
You should be all set. I hope this solution works out for you and good luck.
Apr 22, 2011 | Televison & Video
There is a DVD stuck in the built in DVD player in
try unpluging set while tv is on and plug it back in it should come out
Feb 03, 2010 | LG Televison & Video
TV/DVD Combo will not switch back to live TV when DVD is ejected.
I had the same problem with the same unit when I first bought it a few months ago.
First up remove the DVD. If the TV stations do not appear within a couple of seconds press the "TV" button (top, second from left) on your remote control.
Let me know if this doesn't work.
Apr 28, 2009 | LG 26LG30 26 in. LCD TV
Hook up to tv
hello there. name is ryan lets see if this helps.
typically in a combination unit there is no rca audio ouputs on the tv. reason being is it is a combo unit not meant to be a item within a home theater system. it has the whole home theater built in it. ;) however if there is any audio output jacks on the tv you should be able to wire the surround sound unit up via rca cable output from tv to input on reciever for surround sound
Feb 13, 2009 | GPX DV7500 System
CD PLAYER HP 6000 LAPTOP
dear sir.
u have to install software for playing cd or dvd and for that u need to download from intenter it's called VLC player or a power dvd , or yr pc has windows media pleayer but windows pleayer has autoplay applaction is desible... so u have to downlaod pleayers it's help u...:)
thanks
jo_chinmay
Jan 02, 2009 | HP OmniBook 6000 Notebook
Umi freeview dvd tv combo to surround sound
I am not familiar with the manufacture and model of your TV set. This does appear to be a compatibility issue between the TV set and its DVD player, and the surround speaker system. The TV set may not be able to directly send the proper information to the speakers. I would consider to call the manufacture support people to have a definate answer.
Jerry G.
Dec 28, 2008 | Philips 17MD250V 17.1 in. LCD TV/DVD Combo
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
Tv/dvd combo
The DVD built in, is a standard DVD player. I don't think Blu Ray or HD-DVD was standardized at the time, and if they were, were quite expensive at the time.
Dec 24, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
Grundig GU19WDVDPCX 19 in. LCD TV Logo
516 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
