My epson c900 slips about 10 cm on the first page that it printed and is then fine from there... any suggestions
  • 14 Answers
SOURCE: Epson C900 print shifted down page -
hi chara
chara i have delayed to respond to your question because i wanted to simulate your situation. To say the least i have setup my machines to the dimensions you have mentioned but i still get good prints with obviously that final message that "incorrect paper size"
pass more details on 1. ms image version 2. printer settings (reset all to default) 3. ms image printer properties settings.
i have a feeling that this problem come from ms image end
Posted on Dec 20, 2007
Basti
  • 1447 Answers
SOURCE: Epson Photo R265 Lines every 2.5 cm
If its doing it on all types of paper despite of any setting on printer driver, chances are you are having a hardware issue with the product.
pls try this site: support.epson.com try use passcode; lock
only applies for US printers
pls dnt 4get to rate soln hope the site will help thanks
Posted on Apr 07, 2008
  • 489 Answers
SOURCE: How do I clean print heads re Epson Aculaser c900
Laser printers don't have printheads.
Posted on Jun 07, 2009
tigertail
  • 163 Answers
SOURCE: No print on the RHS of page using Epson Aculaser C1100
Two things to check,
1- clean the laser by opening the front cover, pull forward the green lever on the R/H side, take off the little panel on the R/H side of the printer and pull out/push in the lens cleaning "stick". Replace panel and push the lever back in, close the front and try a test print.
If that didn't work:
2- Open the lid, lift the orange lever and remove the photoconductor. Be careful with it as it is easily scratched. Inside the printer rotate the toner cartridges and check that the cartridge lock levers are fully locked as even a couple of millimeters can block the laser.
Hope this helps.
Posted on Sep 09, 2009
Testimonial: "Solved my problem immediately - very many thanks for the expert advice."
  • 26 Answers
SOURCE: epson stylus dx4000 printing blank pages . how do
replace cartriges, clean printers heads from utility menu
Posted on Oct 25, 2009
Problem printing multiple copies of a single page document
I have a similar problem with an old HP LJ1300. They have not updated the driver correctly and don't intend to fix it. I can't find any reference to AcuLaser C900 on Epson's support page. So maybe they stopped supporting the C900.
May 06, 2010 | Epson AcuLaser C900 Printer
My epson rx420 only prints the left hand side of any document ??? Can any one help please . many thanks
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page. example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
C900 Colur print problems
Print a self made test page in word, a bar of bright yellow, bright cyan, bright magenta (almost pink) and black.
You might find one is completly missing, if so its a faulty toner or maybe the pull strip did not rip out correclty.
Jun 23, 2008 | Epson AcuLaser C900 Printer
Toner Capacity
This does not need to be done. there is a chip/fuse built into the toner that basically tells the printer how many paes that toner has printed in its life time. no adjustment is needed it is all automatic
May 31, 2008 | Epson AcuLaser C900 Printer
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Black stripes ove the page
Try cleaning your ink nozzles or ink jets. It sounds like you have a plugged nozzle or two. Your printer program should have maintenance options that allow you to test for plugged nozzles and clean them.
In control panel, open the printing/fax icon, right click on your printers icon, left click properties, then on the bottom of the page the panel that opens you will see a button that says printing preferences, and that should open your print program.
Dec 15, 2007 | Epson AcuLaser C900 Printer
Epson AculaserC900
I did much the same and am looking to see if there is a solution here! Tried cleaning the glass filter, which pulls out about 250mm and is located just below the transfer unit - small grey tab, behind waste collector. It helped, but still a slight white band on the print.
Oct 22, 2007 | Epson AcuLaser C900 Printer
OK after messing about with the drivers I got it to work. I downloaded a driver from Epson singapore and it made no difference. So, I re used the driver from Epson UK and hey presto the thing works again. Why? Good question. Maybe the people in Epson have no idea either.
So, I suggest deleting the driver rebooting the system and reinstalling it. I hope you get it working.
Oct 08, 2007 | Epson AcuLaser C900 Printer
Colours printing really faint
dear sir you should check the colour mixing detect sensor
Sep 26, 2007 | Epson AcuLaser C900 Printer
26 people viewed this question
jasbo
jasbo
