Question about Lexmark P6250 All-In-One InkJet Photo Printer
Paper won't catch as it is fed into the printer
Solution for error code 005-196
This is essentially a paper size mismatch which causes a paper jam. Technically you submitted a print job for a paper size that did not match the paper which was fed into the printer. Example, your document is legal size but the printer pulled a letter-size paper. As it passes through internal sensors along the paper feed path, the paper size doesn't match the document size (created on the PC) and so the printer stops with the paper in its path posting the error and causing you to have to remove the paper from the jam area. The resolution is either provide the correct size paper based on the document settings in the PC application (may need to be fed in the printer's manual paper tray) or change the document size within the PC application to match the size of the paper being fed into the printer. (Paper size can also be modified in the printer settings on the PC.)
Nov 18, 2014 | Xerox WC7232 Printer
Paper crinkling
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 12, 2010 | HP LaserJet 3015 All-In-One Printer
Several pieces of paper fed in printer and now I have a paper jam and cannot remove the paper
...look at the printer manual to remove jams. Some time you may have to remove the difuser to get rid of them. Depending what type of printer you have. Remember you can go on line to download the manual if you don't have one available. Check if the paper is catching excesive mousture and that the roller that catch the paper have been given proper maintenance. Tks.
Jan 14, 2010 | Kodak ESP 5 Printer
My printer saying no paper fed there is paper in it and no paper jam doesn' seem to be catching paper
clean the rollers that help the paper feed into the machine with a clean cloth and rubbing alcohol...
Dec 21, 2009 | Brother MFC-465CN InkJet Printer
Brother Laserjet 8860dn printer not picking up/feeding paper
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
To check, press the purple lever at the right front of the tray. The leading edge of the stack of paper in th etray should rise out of the tray so that the top piece of paper can be fed into the drum assembly. If the stack does not rise evenly, or will not rise, the rear adjustment is the problem.
You can inspect the springs in the paper tray by removing the plastic cover that is above the white translucent roller in the tray. To do this turn over the tray and release the catches with a little screwdriver. I do not think there is a missing spring. While you have the cover off clean the lnt from behind the roller.
Oct 01, 2009 | Brother MFC-8860DN All-In-One Laser...
Rollers for paper feed
what do you mean too tight ?????????
check the path and make sure there is nothing catching the paper
Oct 16, 2008 | Canon Office Equipment & Supplies
Paper Jam Help Please
If your location is too humid, paper can stick together. If it's too dry, static electricity can also hold paper together.
Incorrect paper thickness / weight can also cause this.
It's a good idea to 'fan' the paper before inserting it, and make sure the paper thickness/weight & room humidity levels agree with those in the specs at the back of the printer manual.
Sep 16, 2008 | HP LaserJet 1000 Printer
When the paper is being fed into the printer it is only catching at one side and will not feed the paper down into the rollers. I have tried cleaning the rollers as it says in the manual but this does not...
You can see into the feeder area on some printers. If it looks like the rollers are moving on both sides, use clean, flat paper, and avoid humid conditions. Sometimes humidity can cause slight curls on the edge which interfere with the grippers.
If the grippers are not working on both sides, you may need a repair.
Jun 09, 2008 | Office Equipment & Supplies
Lexmark P6250 All-In-One InkJet Photo Printer Logo
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
