Question about Apple iPod touch
Frozen itouch itunes and usb connection on screen.. Itunes says ipod in recovery mode you must restore... If i restore will i loose all my data on the ipod..eg..phone numbers etc.. Diary entries....etc
  • 342 Answers
Sadly that is the resolution that will resolve your issue. I know it is a real bummer loosing that information. I have had it happen once as well. I now have a paper copy of my phone numbers as a back up so I will not loose the nubmers again.
To restore your iPod touch, first make sure you are using the latest version of iTunes.
Next, connect iPod touch. In the left column under Devices, click on your iPod touch, then click on Restore in the Summary tab.
Posted on Dec 27, 2009
Disabled itouch
Try restoring the iOS device if backing up and erasing all content and settings doesn't resolve the issue. Using iTunes to restore iOS devices is part of standard isolation troubleshooting. Restoring your device will delete all data and content, including songs, videos, contacts, photos, and calendar information, and will restore all settings to their factory condition.
Before restoring your iOS device, Apple recommends that you either sync with iTunes to transfer any purchases you have made, or back up new data (data acquired after your last sync). If you have movie rentals on the device, seeiTunes Store movie rental usage rights in the United States before restoring.
Follow these steps to restore your device:
1. Verify that you are using the latest version of iTunes before attempting to update.
2. Connect your device to your computer.
3. Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
4. Select the Summary tab.
5. Select the Restore option.
6. When prompted to back up your settings before restoring, select the Back Up
option (see in the image below). If you have just backed up the device, it is not
necessary to create another.
7. Select the Restore option when iTunes prompts you (as long as you've backed up,
you should not have to worry about restoring your iOS device).
8. When the restore process has completed, the device restarts and displays the Apple
logo while starting up:
After a restore, the iOS device displays the "Connect to iTunes" screen. For updating
to iOS 5 or later, follow the steps in the iOS Setup Assistant. For earlier versions of
iOS, keep your device connected until the "Connect to iTunes" screen goes away or
you see "iPhone is activated."
9. The final step is to restore your device from a previous backup.
If you can not restore your device then you will need to go to recovery mode.
Placing your device into recovery mode:
Follow these steps to place your iOS device into recovery mode. If your iOS device is already in recovery mode, you can proceed immediately to step 6.
1. Disconnect the USB cable from the iPhone, iPad, or iPod touch, but leave the other end
of the cable connected to your computer's USB port.
2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the
red slider appears, then slide the slider. Wait for the device to turn off.
If you cannot turn off the device using the slider, press and hold the Sleep/Wake
and Home buttons at the same time. When the device turns off, release the Sleep/Wake
and Home buttons.
3. While pressing and holding the Home button, reconnect the USB cable to the device.
The device should turn on. Note: If you see the screen pictured below, let the device
charge for at least ten minutes to ensure that the battery has some charge, and then
start with step 2 again.
4. Continue holding the Home button until you see the "Connect to iTunes" screen.
When this screen appears you can release the Home button.
5. If necessary, open iTunes. You should see the following "recovery mode" alert:
6. Use iTunes to restore the device.
Dec 26, 2013 | Apple iPod touch
Tip
How to restore a Disabled iPod
This tip work with the iPod and the iTouch, it doesnt matter the generation
Follow the next steps
  1. Turn off your iPod
  2. Hold on the menu button for a 5 secs
  3. While your are pressing the th button connect the iPod to the USB cable already connected to the PC with the iTunes opened
  4. iTunes send you a message that says: "iTunes has detected and iPod in recovery mode an you have to restore before using with iTunes"
  5. Just wait a little to get the iPod restored
on Apr 01, 2011 | Audio Players & Recorders
My itouch has a passcode and i forgot it, when i try to type it in my itouch gets disabled, and when i try to plug it into itunes it wont go to it so i can restore it because i need the passcode
To resolve this issue, you will need to restore your iPod to factory settings This means any data (music, movies, contacts, etc.) will be erased and the iPod brought back to it's factory settings (like the day you got it).
To do this, follow the steps below:
1. Make sure your iPod is disconnected and powered off. If it's not already, hold down the power button until the "Slide to Power Off" message is displayed and swipe to turn off.
2. Connect the USB end of the data cable to your computer, do not connect the other end just yet.
3. Connect the other end of the data cable to the iPod and immediately press down & hold the "Home" button.
4. Continue to hold down "Home" button , until the iTunes logo appears and the USB connection is displayed on the iPod's screen.
5. Open iTunes (if it hasn't opened automatically) and a message stating that it has found an iPod that is in recovery mode. (If you don't get this message and the iPod just boots like normal, then the timing between connecting the iPod and holding the home button wasn't fast enough. Try again from step #1).
6. Click the "Restore" button and iTunes will automatically download and install the latest iOS version for your iPod.
The process should take about 20-45 mins, depending on your internet connection. Once complete, the iPod will reboot and your iPod will be restored to factory settings.
Since iTunes requires that all data be synced through there, if you have made any backups to your iPod, you'll be able to re-sync your information back to your iPod at this time.
Aug 11, 2010 | Apple iPod touch
My itouch is locked with a passcode and it shows the itunes with the USB port pointing at it and when i plugged it into my itunes it said that it couldnt connect to the ipod because it was locked by a...
Okay well you have to do a full restore. Turn your itouch completely off. With it off, hold down the circle button and plug in the USB cable connected to your computer. The itouch will power on and you will see the apple, but keep holding in the circle button. After 15-30 seconds, you will see another (different) cable/itunes screen on the iphone. iTunes should then recognize that the itouch is in recovery mode and you can then do a restore. You should be good from there.
Remember, turn off the itouch. Then while its off hold down the circle button and plug it in. Keep holding down the button until the recovery screen comes up. Good luck!!
Now
May 18, 2010 | Audio Players & Recorders
How do i unlock an itouch without my password?
How to unlock IPod touch Password? You can unlock your IPOD Touch passcode or password by following these simple steps.
  • Connect your IPOD Touch to iTunes
  • Press or Hold the power and home keys 10 seconds.
  • Screen goes black, now release the power button
  • Make sure you do not release the Home key until your iTunes says "We have detected an itouch in recovery mode."
  • After this its simple all you got to do is a simple restore using your iTunes
Apr 19, 2010 | Apple iPod touch
Enter passcode screen is on, unable to enter code, appears frozen
you can fix it by restoring it in iTunes.
Here is a way to put it in recovery mode.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Iphone and itouch dfu mode
Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
Jun 10, 2009 | Apple iPod touch
My itouch says connect to itunes but it wont let me
You will want to reset the ipod and reconnect it to your computer. Below I have posted step by steps on three trouble shooting options. If after a reset it still will not connect to the computer, proceed to step two. Putting the iPod into recovery mode. Then if in recovery mode you can get it to connect to the computer, restore it to factory settings. Restoring it is listed as step three. I left the restore article normal in case you can get it to connect with just a simple reset.
1st reset
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
2nd RECOVERY MODE
Connect your USB cable to the computer without the iPod connected at the other end.
Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message: iTunes has detected an iPod in recovery mode. You must restore this iPod before it can be used with iTunes.
If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPod and repeat steps 3-6.
Because you must restore the iPod touch, iTunes will not recover data from the device, but if it was previously synced on the same computer and the same user account, it should restore a backup (if available)
RESTORE Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
If none of this works and your iPod is still under a year old I would call apple. Make sure that you inform them of the trouble shooting you have already done though. They can tend to assume people don't do trouble shooting. GOOD LUCK
May 05, 2009 | Apple iPod touch Second Gen (8 GB,...
My itouch is disabled and i dont remember my password. i try 2 connect it to my computer thru itunes but it wont show up because it says it is locked.
i had the same problem. this is all the steps needed, calling apple isnt necessary.
first: press down on the top power button and on the menu button
second: keep pressing, eventually the screen to turn it off will pop out. ignore it and keep pressing.
third: the itouch will turn off completely but dont stop pressing
fourth: the apple sign will come out. you may now release.
fifth: now you should be able to connect to itunes that will restore your ipod.
your welcome.
oh and get some ice for your fingers . lol.
Jun 30, 2008 | Apple iPod touch
Itouch unlock password
if you do not know your passcode then make sure it is plugged in 2 the cp and make sure the itouch is on the screen where it says enter passcode. then you hold the power and home button at the same time until the itouch completely turns off and then you keep on holding both buttons until the apple logo again. and after that appears, you let go of the power button but you keep holding the home button until the itouch says its connected to itunes. and then you are allowed to access it on itunes. then you need to restore it and it will restore ur hole ipod and there will not be a passcode anymore
May 14, 2008 | Apple iPod touch
Apple iPod touch Logo
226 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
