Question about Toshiba 46HM95 46" HDTV
Digital board needs replacing
The tv would not turn on, so we took it to a tv repair shop. They said the digital board needs replacing for $875.00. Does this sound correct? Do you think that I can purchase a new digital board and install it myself?
  • 137 Answers
Sounds like powersupply problem not "digital board" Maybe you must get second opinion about that. Is there a remote lite on .Is the set completely dead. ???
Posted on Dec 25, 2007
Fix lcd tv
You need to dertermine if the power board failing charred the connectors, or if a differeb=nt component failed which charred the connectors and took out the power board. This will require component level testing. i suggest taking it in to the repair shop.
However, i would price shop a comparable replacement TV before fixing a 4 year old Insignia. it may be more cost effective to just replace it.
Jan 29, 2015 | Insignia 46 Class LCD 1080p 60Hz HDTV
I have a 50'vizio HDTV 20A, the tv was flashing than it just stopped working. Took to a repair shop they replaced the power supply. Told them about the flashing that was going on (edges of the objects on...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 13, 2017 | Vizio P50HDTV20A 50 in. Plasma HDTV
I took my samsung 50" DLP TV model # HLR5067W to a repair shop and they said my digital board is bad. I also called Samsung and my warranty was up and they said I was basically SOL. Where can I get a...
First thing is look at the model number of the TV and make sure of the complete model number. For instance there are 2 versions of this model requiring 2 digital board numbers. If your model is just HLR5067W the part number is BP94-1858A if the model is HLR5067WAX the part number is BP94-02084A. I bet yours will be the later of the 2 since that is a high failure version. They are NOT cross compatible. The parts you can purchase from Samsung at http://www.samsungparts.com
Please take a moment to rate my answer...Thanks
May 18, 2010 | Televison & Video
Will not turn on and is flashing a yellow light 3 times over and over
I had the same problem with a 32HL67. (Your TV may use many of the same parts.) The TV would not come on, and the only way to stop the yellow blinking light was to pull the power.
Took the TV to a local repair shop, and we jointly decided the problem was either the power supply or the main video board (seine board). We decided to try the video board first. Ordered board PEO249A, part number V28A000320A1 from www.discount-merchant.com (49.95 plus shipping) and had it installed last week. This solved the problem. However, a new problem showed up. The TV now will not scan over the air for digital stations. This is not really critical since I use DirecTV; however, it is good to be able to get the locals over the air.
When the video board was replaced, we discovered that the original board in my TV was PEO361A, part number V28A00043601. This is Toshiba part 75007222. (This board is also available at the same vendor for the same price.) This difference in parts may be the reason my TV now will not scan for digital stations. It appears that replacing the video board with either of these new boards will likely solve the blinking yellow light problem; however, if you use the PEO249A, you may lose the ability to scan for stations. On the other hand, there may be an inherent problem in the PEO361A which may be causing the blinking yellow light problem. Who can say?
Mar 04, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
LG 32LC7D will not display digital channels. Took it to have it repaired, was told the main board needed replacing. Over $350 including parts and labor. Declined repair. Came home, hooked up in my 2nd...
Most likely if the digital channels are dropping off then you might just have to replace the tuner. The tuner on this TV is available separately as part number EBL32758001. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | LG 32LC7DC 32 in. LCD HDTV
Projection tv won't turn on after replacing convergence & resist
STKs are static sensitive, your tv though, also has a digital convergence board that if damaged will cause any new ICs and resistors to fail. you need to have a technician repair this. This is why many of the DYs that seek help on the net would save money, simply by calling on a repair shop. Julio milleniumtvsvc@gmail.com
Jul 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Maxent plasma tv is showing only vertical lines.
Common problem on these sets are many many bad caps on the digital board. Repair kits are available for these containing the necessary parts if you're savvy with a soldering iron. Otherwise, replacement of the digital board is necessary and you'll have to contact either Maxent or a local repair shop. Tracking down which caps are bad can be difficult even with the right equipment as some tend to check good while in circuit when they are actually bad.
May 19, 2009 | Maxent MX-42V1 42 in. Plasma Television
Will not turn on
Check the card connector pins - if a card has been inserted improperly the pins can get bent, shorting the power supply of the camera. The only solution is to have a repair shop replace the fuses, about a $100 -$125 job.
Jun 13, 2006 | Canon Digital Rebel / EOS-300D Body only...
Toshiba 46HM95 46" HDTV Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
