Question about Garden
Trouble shooting electric start toro 20074
Just purchased Toro 20074 electric start, charged battery, fuse new, no reponse when turn the key. Starts with pull cord first time without difficulty but females in the family would like to use ES option. Tips on where to begin?
  • 389 Answers
Check battery connections, make sure they are clean and TIGHT!
Check the harness where it plugs into the starter switch
Check the harness where it plugs into the battery wire harness
Check the cable at the starter, make sure it is clean and TIGHT
If you need it, you can go to toro.com and enter your model number and download both the Owner's manual and a parts manual if that helps you any
Posted on Oct 04, 2009
Trouble shooting New Toro Power Clear 418 zr - slight misses and pops while running
when you start it do u use the choke right , when starting close choke when it starts open choke you prob fouled the plug clean it put back it walah
Nov 22, 2013 | Toro Power Clear 418 ZR - Single Stage...
Have a toro 20074 electric start, charged the battery for a full day, started right away, cutting the lawn, stopped for a break, went to turn the key and nothing, I mean nothing, had to use the pull cord,...
If the motor isn't charging the battery as you work then it will gradually discharge while the engine is running. A faulty battery will also not hold a charge. Make sure the charging circuit is OK and get the battery tested at your local dealer.
Sep 10, 2010 | Garden
I have a toro wheel horse classic 312-hydro. Sometimes when you turn the key nothing. It always ends up starting though. It might take a while but it aways starts. When is does turn over it starts just...
just purchased 1995 says seller, serial # says 1990, 312h kohler wheelhorse 157 hours, royaly maintained, new condition runs great when it starts,turns over great, spins fires spins fires over and over then back fires thru carb, flames this no start, help going to snow tonight
Aug 23, 2010 | Toro Garden
Battery draw down
Disconnect the battery. Charge the battery. Then let it sit idle for whatever period of time that it has been taking for it to go dead. Reconnect the battery & try to start it. If it is dead then the battery is bad, If it cranks OK then you have something drawing the current from the battery.
Sep 10, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Personal Pace Mower won't start w/ electric starter
There are a couple of things you can check;
First, check to make sure the bendix is engaging. It is the gear that meshes with the fly wheel.
If it is, then try and see how fast the motor is spinning. Don't look at the blade though. It could be a faulty starter motor.
Make sure to also check the battery voltage with a volt meter. It should read at 12.0 or higher.
Sep 07, 2009 | Toro Lawn Mower With Toro Power Tools
Turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
May 19, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
593 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
