Question about Sanyo Katana SCP-6600 Cellular Phone
Fell in water , wont power up after i charged it
  • 395 Answers
Please follow the simple steps i am going to outline;
1. Dissemble the cell phone taking out the battery and cover.
2. Get a mini brush dabbed int spirit and clean the panel using the brush. Place them in an airy environment, most preferably out in the sun. Allow it outdoor for say 12 hrs or more.
Fix it back and i assure you that you'll have your cell power back on.
Regards
Posted on Sep 27, 2009
  • 2,200 Answers
The only thing you can do with this phone is leave it to dry over a couple of days. It will not work because the moisture has shorted out the internal circuitry. Do not force it to dry out with anything like a hairdryer as this can often cause more harm to the circuitry.
There's no special magic you can do at this stage to help make it work - it simply needs to dry out and sometimes if you are lucky the phone will work again once this has happened.
I would advise you to remove the battery and then leave the phone in a dry place in your house where air can easily circulate. If you are able to remove any part of the casing this will speed up the process. Do not attempt to dry the circuit board with anything - let it dry itself.
Then wait for 5 days or so and hope for the best!
Hi My Huawei wont charge
fone fell if screen doesn't respond digitizer has gone bad, charger port also damaged I'd recommend getting a new device since it will cost alot to repair that
Apr 18, 2017 | Huawei Cell Phones
I need help to fix my tablet that fell in the water this morning
Put it in a Tupperware container with rice in it for a week. Remove the battery if you can.
Oct 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My iphone just turned off and it wont turn back on ive had it for about 3 years now and the power button is broken about six months ago it fell into a cup of water it was pretty much empty the speakers...
the only thing you can do is is to take to the service center as you said power button is broked ... and phone fell in water... it may have the firmware problem but if u install the new firmware also you need the power button.. so i suggest you to ttake it to service center and repair both problems
Aug 13, 2013 | Apple iPhone Cell Phones
I have a ipod touch 4th 8 gb. It fell in water but was put in rice, screen cracked tho. It all works except when i use the usb port it doesnt make that one sound, show that it is charging, or it wont...
It could be dirty connections. 1) Turn off the device.
2) Take a charge cable and dip it in rubbing alcohol.
3)You then want to take the damp cable and plug it in and out of the device. Do this a few times, and then make sure it is dry before you plug it into any power source.
Aug 13, 2013 | Apple Ipod Touch 4th Generation
My phone accidently fell in water now it wont restart completely ... what do i do?
Dont switch on the phone or charge it unless the water gets fully drained.
Unscrew your mobile and take the ic chip and blow some hot air using hair dryer for some time unless the water gets drained.
After the water is completely drained replace and screw the mobile and switch on..
If problem still persists you should replace your ic chip..
There is no other go..
Thank you for using fixya..
Please rate me on fixya to continue my further assistance..
Jan 12, 2011 | Samsung Galaxy S GTI9000 Smartphone
It wont turn on, it wont charge, Power Supply? how to fix it?
It's broke. Would probably cost more to fix it then to buy a new one.
If you are so inclined though, you can try opening up and see if you can find something loose.
Apr 04, 2010 | Nintendo Game Boy Advance SP GBA Red...
It fell in water and wont turn on or charge
As you will appreciate - water and electronics do not mix. The soaking in the water will have caused a short to occur somewhere on the circuit board or other components.
One key to saving soaked electronics is speed and the ability to rapidly remove the battery to prevent power being supplied to the short. The battery in this unit is pre-installed and is not removable so unfortunately it is highly likely that the unit will be beyond repair I am afraid.
However, sometimes you can be lucky. If the unit was not too badly immersed in water, there is a possibility it will work again if it is left to dry out in a warm area of the room.
Do not use hairdryers or heat of any form as this will make the problem worse not better. Using warm sunlight in a window or left in the vicinity of a radiator (but not on the radiator) - gentle warmth is the best approach.
You should wait 2 or 3 days with it drying out in this manner before you try powering up or charging it again. If a fatal short has not occurred this approach can sometimes work but unfortunately there is no guarantee.
Hope this information helps. Thanks for using FixYa.
Jan 23, 2010 | SanDisk Sansa Clip MP3 Player
My samsung rant fell in some water is their any way to fix that or no
disassemble it as much as you can. leave it in a dry warm environment for about a week to dry out. put it back together in about a week. charge up the battery and power it up. cross your fingers it may work.
p.s. was it on when it fell in the water ?
Nov 13, 2009 | Samsung Rant Cell Phone
Hp nc8000 power issue
Many of the power jacks also contain switch contacts that allow the adapter to power both the laptop and the "charging" system. I would suspect that one of the leads had either been broken or at least detached from the pc board. This laptop needs to be dis-assembled and the power jack repaired. Worse case will result in the replacement of the jack or the repair of the board if that part has been cracked.
Dan
May 13, 2008 | HP NC8000 (DE503AV) DVD+RW Burner
Fell in sea / wont turn on
would you like the bad news or worse news first? salt water begins to corrode almost instantly (bad news) time to buy someone a new cam (worse news) sorry
Jun 07, 2006 | Casio Exilim EX-S1 Digital Camera
Sanyo Katana SCP-6600 Cellular Phone Logo
76 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
