How to disable sata native mode on toshiba satellite pro
  • Jaye Ellen Burke
    Jaye Ellen Burke May 11, 2010
    What's wrong with SATA Native Mode? It works flawlessly for most everyone.
  • 32,281 Answers
Go into the BIOS, there should be a setting to turn off native mode SATA.
Posted on Sep 27, 2009
    Novelist:
  • 225 Answers
Try checking the bios. follow toshiba manual on changing values in the bios.
Posted on Oct 10, 2009
    President:
  • 2,600 Answers
Get into your BIOS by tapping either the delete key or the F2 key while the Toshiba splash screen is showing. Once in there you can manipulate the core and peripheral settings.
My Toshiba satellite Ox3bc3
Repair action: Partition table repair
Result: Failed. Error code = 0x3bc3
No OS available probably due to a SATA error.
Try disabling SATA Native Support in BIOS.
Nov 02, 2013 | Toshiba Satellite Computers & Internet
I have toshiba satellite L505-S5990 model.i have installed windows xp by changing the settings in Bios that is sata hard disk enabled as compatable mode from AHCI.if i change to AHCI i can't install...
If you would like to make use of the SATA controller's AHCI features, you should enable this BIOS feature. But please note that enabling this feature requires you to load the SATA controller driver during the Windows XP installation routine.
If you do not intend to use the AHCI features, it's recommended that you disable this BIOS feature. This allows you to use the native Windows XP driver. You won't need to load the SATA controller driver during the Windows XP installation routine.
Read more: http://www.techmetica.com/howto/sata-ahci-mode-bios-setting.-what-does-it-do/#ixzz0y5ObAtN8
Aug 30, 2010 | Toshiba Computers & Internet
Pxe-e61: Media test Failure check cable Pxe-mof: Exiting PXE Rom Operating system not found what can i do?
in order to load the Operating system I request you to disable the SATA Native Mode in BIOS and then load the Operating system. 1. Please perform the below steps for the same:
a. Restart your computer.
b. When the F10 setup message appears in the lower left corner of the screen, press the F10 key.
c. Locate ‘System Configuration’ and then select ‘Device Configurations’.
d. Under ‘Device Configurations’, select ‘SATA Native Mode’ and disable the same.
e. Save the settings and exit.
Once the SATA Mode is disabled, please install the Operating System in the normal fashion using the Recovery CDs or the Operating System CDs that you have. Before installing the same, you need have the SATA Controller driver. Please follow the ’Installation Instructions’ in the SATA controller driver link given below.
2. Download the latest “Intel SATA AHCI Controller Driver” driver from the below mentioned link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId
=321957&prodSeriesId=3356620&prodNameId=3356622&swEnvOID=1093&swLang=13&mode=2&taskId=135&swItem=ob-54270-1
Upon installing the same, please get back into the BIOS and enable the SATA Native Mode.
Note: The third-party information provided is to help you find the support you need. This information is subject to change without notice. HP in no way guarantees the accuracy of this third-party information. The software manufacturer will provide support for this software.
Please update your observation for us to serve you better.
I have also given you the link below for the XP Professional Drivers:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId
=3356622&prodTypeId=321957&prodSeriesId=3356620&swLang=13&taskId=135&swEnvOID=1093
The above given information are pertaining to HP 6710b Notebook PC. If you do not have the same, please update the serial number for us to given you more information.
May 03, 2010 | Toshiba Satellite A105-S2051 Notebook
How to disable SATA on Toshiba satellite A205
Why would you want to disable it? Chances are it is a SATA HDD installed.
Apr 22, 2010 | Toshiba Satellite A205-S5812 Notebook
Do i need (s)ata drivers for toshiba satellite u400? or i can install xp without a problem?
Start your laptop and goto your BIOS and check if SATA setting is available.if available then configured it in IDE Mode or disable it, (if disable option is available).
Now, you should be able to installed windows XP without any problem;
Usually these days,Laptop BIOS comes with little or standard setting;if that is the case;then you will need SATA driver during installation in other to recognise your SATA hard drive.
Dec 14, 2009 | Toshiba Satellite Pro U400-S1001V Notebook...
80 gb toshiba laptop is not detected in the bios. What could be the cause?
When you power up the computer press F1 or F2 or "del" key then go to advanced .
Then disable SATA .
If already disable then enable it then save settings then check.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Toshiba 100GB Laptop for Satellite 2400,...
Urgent
I think the general problem with XP is now 'Hard Drive Not Found' error.
If the same case is with you then you need to download RAID dreiver for your SATA IDE or you have to make disable the SATA from your bois. If you can make disable SATA then XP will be installed. But if you can't have option to make it disable then you have to download driver as per your motherboard.
I think it will help you.
Thanks
Iqbal
Mar 22, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Can't reinstall xp pro on my hp compaq nc6320
Stephane, I ran into the same problem after wiping out my Compaq nc6320 and trying to install XP Pro. The fix is to disable SATA Native mode. To do this: Enter F10 Setup then System Configuration>Device Configurations>SATA Native Mode and disable it, save the changes and now you should be able to install XP Pro. Remember, when I did this the drive was blank, I don't know if that makes a difference or not. Best of luck! Bryan P.S. If you want to enable SATA native mode after you have installed XP Pro check out this link: http://forums1.itrc.hp.com/service/forums/questionanswer.do?threadId=1042050&admit=-682735245+1161793137260+28353475
Oct 04, 2006 | HP Compaq nc6320 Notebook
Computers & Internet Logo
1,987 people viewed this question
David Payne
David Payne
