Question about Numark TT200 Turntable
Im getting loads of feedback through my speakers from my turntables but i havent got a ground wire is that the problem
  • Numark Master
  • 5,342 Answers
Could be, is the earth leads to the cartridge lose or fitted wrong? Has the connection cable become faulty? Does the power plug have an Earth wire? Remove it if it has been attached.
Posted on Nov 28, 2009
  • 189 Answers
HELLO
This problem is usually caused by the turntable(s) being too near the loudspeakers - a sort of "howlround" effect if you like.
Make sure that the speakers are as far away as possible from the decks and that your cartridges are set up correctly too. On the back of the turntables, there should be a connection for a ground wire, but that should have nothing to do with this situation.
Hope this has helped, and good luck! (:-)
Posted on Sep 27, 2009
WHY DO I GET LOAD FEEDBACK WHEN I PLUG TURNTABLE INTO RECEIVER?
it may not be feedbacl, but ground hum. make sure the turntable is grounded. the turntable should have a ground wire with one end stripped. Bend the stripped, bare wire into a u shape and hook it around the ground screw of your receiver and tighten it down. If your turntable is already grounded, it may be feedback. you may have speakers too close to the TT or your volume is too high
Mar 21, 2016 | Technics Audio Players & Recorders
Technics SL 1210 feedback/grounding problem.
Do you have these turntables on an anti-static mat, or some other non-conductive surface?
Jun 09, 2008 | Technics SL-1210 Turntable
I have a RCA turntable that will not play without considerable distortion when plugged into the "phono" input of two different recievers. It will woek when plugged into the "Tape "input...
The RCA Lawton turntable probably has no grounding wire. Most receivers require a grounding wire from the turntable to the receiver to operate properly.
Jan 15, 2011 | RCA Lawton 841.662 Turntable
Technics 1210's playing out of one speaker / channel
Have you considered the amp to be the problem? The amp has a magnetic cartridge pre-amp, which only the turntables would use, that can fail. It's often a single IC that has gone.
May 13, 2010 | Technics SL-1210 Turntable
Hi there! i just bought a numark tt1650 and an ortofon arkiv cartridge, connected it properly to my old technics a700mk2 amplifier (phono, grounding and all that) but it still has a buzzing problem...
Try connecting the turntable to one of the other inputs like CD / tuner etc and see if the buzzing disappears. if so then your turntable has a built-in pre-amp so it can be connected to any input except 'phono' as this would obviously be used for turntables without a pre-amp.
a lot of modern turntables now have built-in pre-amps to compensate for certain amps and receivers made without a phono input and can now be connected just like a CD player, tuner etc.
hope this helps.
May 05, 2010 | Numark TT1650 Turntable
I just purchased a Technics SL-BD22 turntable and it came without the ground wire. Is there anywhere I can purchase this proprietary part?
just get any small speaker wire and use that as your ground , attach that to the reciever you are using
Jan 16, 2010 | Technics SL-BD22 Turntable
Major feedback hum from speakers
The reason for the hum is as follows:
1) The phono input on the receiver contains an additional stage of amplification required for typical turntables.
2) Pluggin in a unit that has a signal level too high will generate this hum.
3) Your turntable contains an pre-amp that allows it to work using an aux input (or tape input) as most receivers today no longer have phono inputs.
4) Grounding issues relate to the older types of turntables where there was NO pre-amp stage inside the turntable. In this case ,the signal levels were so low that stray noise would often get in the way of the signal. Proper grounding would elimiate this noise.
Hope this helps.
Dan
Aug 10, 2009 | Sony PS-LX250 Turntable
Hum from ION turntable
need to be earth,attach wire form turntable to something that¬s earth
Jan 25, 2009 | Numark ttUSB Turntable
Have a B&O RX-2 with mcc4 and loud hum
Possibly check the wires on the cartridge, make sure none of them are touching and are not bent to badly, are all the connections tight? some cartridges require plastic sleeves over the connections, this insure they don't touch and
avoids resistances between them. Also some cartridges are not compatible with certain model turn tables.Is it universal? Also you my need a mixer most turntables don't work with amps alone. Mine don't. Usually most models you attach the ground wire to the mixer. A mixer boosts table power and take stress off the amp. Hope this helped! good luck!
Jan 31, 2008 | Sony PS-LX350H Turntable
Feedback humming noise
This is a tonearm issue. Your tonearm probably has a loose ground connection, or if you moved it recently, may have been damaged in transit. Also, try and move your turntable to a different location in the room. If your near any serious power source (light dimmer switch, microwave, frig, etc), it will only amplify the issue. But other than that, it sounds like a common tonearm issue, and you will need to have your tonearm replaced.
- TWEAK AV LAB
Dec 10, 2007 | Technics SL-1200MK2 Turntable
Numark TT200 Turntable Logo
242 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
