Question about Cameras
Unable to clear a photo as it is protected and i havent got the manual to do it myself
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
I havent used my camera for a few years as the lense was broken. I purchased a new one today, but have forgotten how to use my cameras functions. It is a MINOLTA DYNAX 500si and I am also unable to find...
You can download the manual in two parts.
Part 1:
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_400si/Maxxum400siManual-Part1.pdf
Part 2:
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_400si/Maxxum400siManual-Part2.pdf
If you have problems with the above links, try
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Mar 31, 2011 | Minolta Cameras
Photo is locked on camara unable to remove key symbol
I don't think there's a single manufacturer that makes this clear. But let me tell you their little secret... whatever you did to protect it - do it again. It's a toggle function! They wouldn't want to put "protect/unprotect" in the menu system instead of just "protect", it might look 'cluttered'. Of course, it might be more useful too.
Mar 24, 2011 | Olympus FE-310 Digital Camera
I have a vivitar vivicam,i havent used it in a
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 15, 2010 | Vivitar ViviCam 8025 Digital Camera
How to delete pictures from a d-460
Judging by your explanation, the photos are on your sd digital memory card rather than the internal memory.
Since you are unable to delete just those 15, it sounds like you might have accidentally enabled the "protect" function.
Get out your manual (or download a new one) and read about how to protect/unprotect photos, and also read about how to format your card in camera - something you should do on a VERY regular basis for the health of your memory card.
While you have the book out, read ALL of it - twice! You'll be amazed how much you'll learn.
May 01, 2010 | Olympus Camedia C-350 Digital Camera
I have a vivitar vivicam,i havent used it in a while. I just tried to take pictures and it says card protected. It lets me look at allthe features and my old photos but not take new ones. When i try CARD...
There is a little, and I mean little, lever on the top left, and if it's in a Locked positions...it is "protected"...move the lever to the Unlocked position and you shouldn't have any problem.
Mar 28, 2010 | Vivitar ViviCam 8025 Digital Camera
My Memory card has "protected card
try this 2nd pt 1:
have u tried getting into playback mode:
press the play button then click menu/ok button
scroll dwn to protect select reset all i think that would fix this problem...
* try this 1st:
u should also check if the very tiny button on the chip is set to lock its usually white or grey on the side of the chip, for a while i didnt know the thing existed ,LOL
2nd solution pt 2: then see if the pics r protected or not and manually remove the "lock" the symbol for lock is shown then itll change to unlock
not sure why u cant upload
if u have a program u have to "upload twice"
if u get the pics viewable on your pudder u still have to select all (some) and upload them and hope it doesnt crash or ull have to retry make sure u have enough free space and the camera has fully charged batteries
depending on the program u might have trouble uplaoding, (if u have to "manually upload" thats a bit more tricky havent done that myself b4 but my hubs can)
ive had the same problem at times w mine i dont use the program it came w.
Jan 04, 2009 | Fuji FinePix A800 Digital Camera
Unable to view the pictures folder
Hi, I got the solution for myself. Initially I have enabled to view the hidden folder option and even then I was not able to see the folder, then later I have disabled the options Hide Extensions for Known file types and Hide Protected Operating system files. Then I could see the folder and able to retrieve the photos. Once I have taken my photos I have formatted my MMC card and it is working normally.
May 19, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
These are the numbers
So far I havent been able to find any info on your models chassis. I will continue searching and soon as I can locate anything I will repost.
Mar 25, 2008 | Televison & Video
When swithched on the camera getting message protected card and unable to shoot photos
Try to slide the little switch on the side of the card in the other direction. That switch is like a write protect for the card. Good Luck.
Nov 16, 2007 | Gateway DC-T50 Digital Camera
Cameras Logo
13 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
