Question about Mitsubishi CS-35707 35" TV
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and the screen just scrolls. It does it on 2 of the inputs (did not check any others). I tested it with a dvd player and cable. Any ideas?
  • trick3900 Feb 19, 2008
    I have a mitsubishi CS35301 and the picture keeps rolling is there a horizontal hold button to adjust?
    Genius:
  • 1,153 Answers
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Posted on Dec 17, 2007
My tv mitsubishi vs-60705 looks great when i first turn it on after it warms up picture starts to shake and gets worse the longer its on. what is overheating to cause this ?
Sounds like you have a swollen cap in your horizontal hold circuit. Look at your board closely, and I am sure you will find one that is bulging on the top. Just replace with the same value.
May 16, 2011 | Mitsubishi VS-60705 60" Rear Projection...
Television turns itself off after being on for about 10 minutes
Run the diaginostic that you find in the pdf user manuel...1st
Nov 11, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Horizontal lines in the picture.
Give it time to warm up like another 10 to 15 mins i find put a tv guide channel on the screen stays pretty much the same picture, then leave the TV on" i use a 4 hour rule if i dont view in 4 hours or more i will close tv power
Oct 07, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705, Turns on/Turns off.
Unfortunately you will need an experienced TV tech.
This unit will need 2 ICs STK392-110 for 1 has shorted and caused damage to the 2nd as a result blowing 1 or 2 pico fuses in the power supply.
It is an involved job and may be somewhat costly depending on the pricing in your area.
Hope this helps Normal 0 false false false MicrosoftInternetExplorer4
Jul 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Vs-60705
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility that works on rear-projection TV's should be able to repair your set. I bought the set on Jan 1, 2000. Coming up on 9 years and the set works like new.
Jul 30, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Televison & Video Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
