Uniden Cordless Phone Logo
Posted on Sep 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HoW DO YOU BLOCK A CALLER ON THE UNIDEN 9480 - Uniden Cordless Phone
Anonymous
Level 2:
Scholar:
  • Expert 43 Answers
  • Posted on Sep 27, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
43
Questions
0
Helped
27918
Points
151
Call Block is a service provided by your phone carrier. For most providers you dial *60 (star 6 0) and follow the voice prompts. After you have blocked this number, you will not receive any more calls and it will not ring through from the number you blocked. The phone device itself does not have that capability. Only your service provider.
Can I block a incoming number if so How?
Yes, when the number comes up, open a screen and scroll down to block number.
I have activated the caller id block for my outgoing calls. How do I reverse this process so that my number shows up to the people that I call?
The procedure depends on your phone company, not on your phone. With some phone companies, for example, dialing *82 before dialing the phone number will deactivate caller ID blocking for this call.
Please contact your phone company for full instructions.
Need to know what type battery for Uniden PowerMax 5.8GHz Digital Answering System Cordless Phone Model #: TRU 9480 793E 0206W. Phone was given to me and has no booklet. Thanks!
From the manual: To order headsets, additional handsets, replacement batteries, or other accessories, visit our website at www.uniden.com or call 1-800-554-3988, Monday through Friday, 8 AM to 5 PM, CST.
Another source for the battery is
http://www.batteriesplus.com/product/34648-RAYM182-High-Capacity-Battery/549-0/5275-Cordless-Phone-Batteries/130291-Uniden/TRU9480.aspx
You can download a copy of the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/TRU9480om.pdf
5helpful
How to Remove Call Block from Uniden phone
#82 to remove the block from AT&T phone lines. This has to be done before every call if your account is set to block caller ID. Refer to the front section of the white pages if your service is not from AT&T. Beware, some phone companies charge as much as .50 each time you remove the block.
6helpful
Manual for uniden TRU9480 4
Hi streck - Below is the link for your manual. The manual is the same for all 9480 series phones no matter how many extra handsets you have. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.uniden.com/pdf/TRU9480om.pdf
Jeff
Caller ID doesn't display and phone rings 1 time then stops
The Uniden TRU9XXX series has a high level of handset compatibility between bases. Depending on the handsets you bought to go with your 9480, you may be able to buy another model in the series and use the old handsets with the new model. Alternatively, you could buy another 9480 here (the -2 on the end of your model number just means that it came with an extra handset).
Before you do that, though, it might pay to hook up a regular (corded) caller ID-enabled phone to the line and see what happens there when you call. If it works properly, go buy your new phone. However, if you see the same behavior there as with the Uniden, chances are that the problem is not with the phones. Possible other causes could include a fax machine, modem, or other device in-line with the phone; a defective piece of equipment hooked up elsewhere in your house; etc. If nothing obvious applies, you might want to give the phone company another call--just because they couldn't find a problem on their end doesn't mean one doesn't exist.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
