Question about Cameras
Distorted display on lcd of my s730. but no problem with taking photo or displaying it on the monitor.
Kilowatt
SOURCE: LCD screen shows weird colours
Hi, I had the same problem... black and pink horizontal "lines"... I replaced the plastic PCB with the CCD-chip on it, from a friend who had also a F700 but the "lens-mechanic" was broken. Since 31/12/06 I am again a happy man !! Marc, from Belgium
Posted on Jan 03, 2007
Canon will fix this for free, regardless of the warranty situation.
Posted on Mar 19, 2007
SOURCE: vertical lines and distorted colour on display screen
Just as I got on line to this site I saw your problem being typed in and it's the exact same issue I am having with my Finepix 5000. I've owned it for all of 4 plus years with no problems and really decent photos. I'm getting a blurred image with green/magenta colors when I look through the viewfinder. When I take a photo, it shows the same. It wasn't dropped or even barely touched between the last good photo taken and this. Attached is an example of above description. I would appreciate any advise. See below.7ccd05c.jpg
Posted on Feb 16, 2009
  • 5 Answers
SOURCE: My Canon EOS 1000D wont take photos, viewfinder flashes busy
Maybe you drop your battery and they have electronic components inside that could be spoiled, if is that the case, try to change the battery, it appeares to me that the ammount of current the battery is sending to the component is very low even thoe it seems to be fully charged that's why the camera is unable to display anything and the "busy" warning is blinking all the time, I hope you find this usefull.
Posted on Aug 07, 2009
  • 102366 Answers
SOURCE: lcd display not working on nikon d40
The D40 works the same way SLRs have worked for the past half century. Only recently have dSLRs acquired a "Live-View" capability, where you see the image on the LCD monitor instead of through the viewfinder.
I realize this probably wasn't the answer you wanted to see, but that's the way it is.
Posted on Jan 23, 2010
Hi, I started to have an issue with a display of my Tecra M5. The laptop is 2 years old and there has been no problems with it before.. Last week I attached a 32" LG LCD TV to my Tecra as an...
the 32 inch LCD may have a lower display resolution that the LCD on your system. Ensure that the display settings for the LC are at the MAX resolution and 60 htz
Jul 31, 2011 | Toshiba Tecra M5-S433 Notebook
LCD monitor display not visible
the lcd wire connector maybe defective or loosen. also the lcd itself maybe the problem
Feb 15, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
Samsung S730 camera wont take photos with flash
�� When the menu is displayed on the LCD monitor,
pressing the LEFT button makes the cursor shift to
the left tab.
�� When the menu is not displayed on the LCD
monitor, the LEFT button operates as the FLASH
( ) button.
�� Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of
Movie clip mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Jul 23, 2010 | Samsung Digimax S730 Digital Camera
Corrupted display on LCD monitor.
Those lines on the right side show sign of damaged T-CON board, part of the LCD panel assembly, nothing you can do but getting the new LCD panel. The bright section on the screen looks like the backlight lamp reflector got out off the guide channel.
http://s807.photobucket.com/home/budm/allalbums
Sorry for bad news.
May 18, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
Distorted display/aspect HP w1907
This is a common problem with wide screen format.
The way I overcome this distortion is to open a drawing program and draw a circle, some programs require you to hold down the shift key to produce a perfect circle.
I then go to the Display Settings and adjust the screen resolution to get the best display that fills the screen and that gives me the perfect circle.
If this does not work you may need to download the latest video driver for your graphics card and then adjust the screen resolution..
Aug 22, 2009 | HP w1907 LCD Monitor
No display to screen
may be ur AGP card problem to ur pc. or u can check ur lcd monitor cable that is there any leckage. if not found then u can take step what i say. have u installed ur motherboard driver? if not then install it. if not become ok then plz take it to the professional hardware engineer . thanks
Jul 30, 2009 | Toshiba Tecra M2-S730 Notebook
Installed new video card, GeForce 6200, but my Impressions 7LS Monitor now displays distorted and repeated images. Are they compatible? How can I restore my display?
Open up your tower and take the little flat battery out for ten minutes put it back in and power up your pc and this should put your monitor back to how it was.
May 07, 2009 | Impression Products Impression 7LS 17 in....
Distortion
Have you selected the correct horizontal AND vertical resolution for the screen. PC's sometimes don't automatically select them correctly
Jul 18, 2017 | E-Machines E17T 17" Flat Panel LCD Monitor
Distorted digital photos
Most likely the resolution of your desktop has and aspect ratio that in incorrect for your monitor. The native resolution of that monitor if 1440x900. Use the Windows (if using windows) desktop properties to set the desktop resolution to 1440x900.
Jun 09, 2008 | Acer AL1916W 19" LCD Monitor
Cameras Logo
69 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
