Light keeps coming on ink light, printer not printer
I have replaced ink today
  • paul nowicki May 11, 2010
    is it laser or ink jet
I have replaced black ink on a hp deskjet 960c and the red light keeps flashing
I see you replaced the Black in on your HP printer but the light keeps on blinking still.
Make sure that you remove the silicon film from the ink cartridge before installing in the printer, if that file is not removed the contact to the printers ink will not detect the ink cartridge at all.
Also try to remove all the ink cartridges and install all of them at the same time , this is to reset the printer from detecting all the printer ink cartridges.
I hope this helps
Oct 26, 2011 | HP DeskJet 960c InkJet Printer
Red light keeps coming on and green one keeps flashing
is both light flashing alternately? if yes, it means you need to replace the waste ink pad and reset the waste ink counter...
May 20, 2010 | Epson Stylus C62 InkJet Printer
Low ink supply?
Hi There
This is a resetter program tools for the inks and much more.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Apr 30, 2010 | Canon PIXMA MP470 All-in-One Printer
The Check Your printer light keeps coming on. I
did you change the cartridges with O.E.M. or aftermarket? If with O.E.M inks then there is a problem with the waste ink container and it needs to b cleaned.. requires removal of the waste in station which is under the inks on the right side of the printer
Mar 31, 2010 | HP PSC 1350 All-In-One Thermal Printer
Printer wont print ink keeps blinking on system
Hi
You not say what make of printer you got so not can gave you much help, because there is a reset code for different printers, the flashing lights you may be getting it because your, waste ink pads need changing and after this you need the reset codes for it but some times just the reset code will do the trick for it to print again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Feb 07, 2010 | Office Equipment & Supplies
I replaced the black ink and it keeps saying replace ink cartridge. I actually went ahead and changed the color as well even though it did not ask and it keeps saying replace cartridge. HELP! I am a...
Did you replace the ink cartridge with a new one, or did you refill an old one.
Some printers have a memory and can tell which ink cartridge is in them. This prevents them from easily being fooled into printing with refilled cartridges.
Another option is that you changed the ink cartridge without following the specific guidelines for replacement e.g. To replace the ink cartridge, select replace ink cartridge from the main menu, then open the printer panel when the light flashes X number of times.
You might also try unplugging the printer for a couple of minutes the reset it.
Oct 15, 2009 | Office Equipment & Supplies
Error light keeps coming on
Check chip connnector at ink tank and at head carriage. It's may be dirty. Check status monitor? what ink tank not recognized. Press ink light (1-4 times) depends on number ink tank not recognized, press 1 time again, carriage will move co replacement position, unplug and plu again all ink tank, press ink light 1 more.
Jun 29, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Yellow color light keeps going off
Yeah its a pain in the rear - only solution I have found is bite the bullet and replace the ink tank. They have have a chip and if the chip goes bad you are screwed. Mine likes to go out on the cyan tank. Great product Canon.
Jan 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
65 people viewed this question
k24674
