Question about HP GF939ATABA Notebook
Hi, is there any other way to charge my compaq 6710b laptop without charger please
    President:
  • 2,600 Answers
The only other way is to have a friend with a compatible laptop that uses that same battery and charge your batter on his system. Why can you not charge?
Posted on Sep 27, 2009
  • HP Master
  • 32,281 Answers
The battery is charged through the laptop's charging circuitry.
I don't know of any stand alone battery charger for laptop batteries, the laptop batteries come in different sizes and voltages.
Hp compaq 6710b is not powering when i put the powerpack
Does that mean it DOES power up without the battery?
Or by power pack do you mean the AC adapter?
Replace it. either way
Apr 09, 2014 | HP Compaq 6710b Notebook
My laptop hpcompaq 6710b does not power on Ac and the battery doesn't charge. But it works fine on battery. Help me please
The AC adapter is probably bad. Or I've even seen the little pin where you plug it in broken off. But my guess is the adapter is bad. Very common thing to happen to them.
Oct 23, 2012 | Computers & Internet
HP Compaq 6710b not charging powering up laptop
You need to check the voltage on the adaptor. If there is no votlage please check on this link to check on the adaptor.
http://www.fixya.com/support/r5164850-laptop_power_supply
If the adaptor is good then the fault can be in teh motherboard or the charging circuit within. Please check the voltage at the pins of the battery terminals in the laptop to confirm. If so you must get support from HP to estimate.
Aug 22, 2011 | HP Compaq 6710b Notebook
Hi, I have an HP Compaq Laptop 6710B which
Usually this is cause by a defective battery. Replacing the battery should fix if.
Thanks Tonm
Aug 07, 2011 | HP Compaq 6710b Notebook
I have a HP/Compaq 6510b laptop computer and it will not turn on...I have the charger plugged in and the only thing happening is the green light periodically flashes...Is the battery bad?
IF the battery is bad the charge lndicator on the laptop will flash (But not periodically) it will be a constant on-off-on-off..... Best check would be to remove the battery completely and use the adapter/charger power supply only. If it still does not turn on then you either have a bad power jack connection or a more serious motherboard problem. Also is the green light flashing on the adapter/charger or is it the charge/battery indicator on the laptop?
Feb 17, 2011 | HP Original HP COMPAQ 6510b 6515b 6710b AC...
Compaq R3000
r u mention for battery light?if is it true,then the light is blinking because of your laptop want to make sure the power supply charge that battery.if it is in charging condition,the light on.but if the light goes off,that mean, the battery is already full.
But when u use adaptor without battery, the light will goes off because no charging session is in progress which has same behaviour with battery full(during battery full,no charging session occur)
May 12, 2009 | Compaq Presario R3000 Notebook
HP Compaq 6710b
It should be the third button to the right from the top byt the power button. Here is a link to a pdf that shows where everything is on your model.
http://h20195.www2.hp.com/V2/GetDocument.aspx?docid=0900a5a5821030aa&cc=bg&lc=bg
May 23, 2008 | HP Compaq 6710b Notebook
HP GF939ATABA Notebook Logo
163 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
