Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
Hello , I get a message. Detecting array all the time. And pc will not boot
  • tigerblade Oct 10, 2009
    Hello ,
    We have solved the problem. The problem was one of the memory cards , Since was counting anyway was faulty when we have replaced everything boot good.
    Have a nice day.
  • 44 Answers
You need to re-flash your Bios
Posted on Sep 27, 2009
Dell Studio 540 will not start shows black screen with parameter error message
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Feb 24, 2014 | Dell Studio 540 MT Pentium DualCore E5300...
Getting detecting array message
And what else? If the system just hangs at detecting it's expecting to find an array of hard drives attached to the system. Do you have an array that it can boot to? Does it load the OS finally? Was it working before? Did you make changes to the bios ro the array controller bios?
Nov 13, 2013 | Gateway GT4016 Desktop PC
Getting detecting array after opening workstation to dust. Did I move something? Anyone have a picture of inside and what goes into what.? When I turn off power source it says warning, now system is in...
I'm guessing you asked amore generic question earlier. If you were dusting you've probably inadvertently unplugged one or more hard drives. Make sure all the cables are seated properly and try again. You can turn off the error message by entering the bios and resetting the error message or tuning it off all together.
Nov 11, 2013 | Gateway GT4016 Desktop PC
MediaShield ROM BIOS 6.33 detecting array on the screen of an emachine pc
You need to be more clear than that. You say detecting an array? What kind of array? When does it say that? Do you mean you have an array of hard drives installed? If so, then so what?
Sep 25, 2011 | E-Machines eMachines Desktop PC
I have tried to install RAM up to the 4GB maximum and now the boot up screen locks complaining that 'detecting array, no disk reserved for RAID use, RAID disabled'. Any ideas?
This RAID message has nothing to do with RAM, RAID is Redundant Array of Inexpensive Disks.
Maybe you knocked a connector when you installed the ram? This seems most likely to me, check all the hard drive connectors both at the drive and at the board.
Finally if you are not using RAID then disable it in the BIOS and it should boot without complaining, but I suspect you are using it and thats why its not booting, sounds like its set to use raid disks which it cant find because a connector is not in place, but thats just a guess based on what you're put above!
Oct 29, 2010 | Gigabyte GA-K8NSC-939 Motherboard
Everytime i turn on my pc it goes to detecting array, how do i solve this problem?
Does it boot into the operating system after this as post information is normal (detecting hard drives, optical drives etc).
Regards.
Jun 25, 2010 | E-Machines eMachines Desktop PC
Gateway GM4019E intermittent power up problem. At power up it seems to click a couple of times during ''Detecting Array'' then powers itself off never booting the OS. When I remove the sidecover it seems...
it could be a hard drive controller.
Or it could be a raid problem if that's what its looking for go into your bios and see if it finds your hard drives if not then it could be exactly that,
Jul 13, 2009 | Gateway Computers & Internet
SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Jan 30, 2009 | HP Compaq ProLiant ML530 Server
Detecting array...
does any other monitor work? if not than the video card may be bad. or the settings in the bios may be altered. first try this...unplug the tower, open the case and remove the bios/real time clock (RTC) button cell battery, press the power button to dissipate any voltage that is stored. Re-install the battery, plug tower in and power up. If anything was changed in bios everything would go back to default settings and you would have to enter set up to update date/time etc.
Sep 10, 2008 | E-Machines eMachines Desktop PC
Model #w3118
If you can get in setup after pressing F2 check on the advanced chip tab,video and make sure 8mb buffer is selected. save and exit.
F-2 is for setup utility
F-10 is for network boot.
if it stll won't boot up correctly press F8 when booting up and select vga support then maybe get in to the os that way and adjust video display settings after.
Apr 13, 2008 | E-Machines eMachines Desktop PC
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
267 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
