Question about Frigidaire Kitchen Ranges
Have brand new range with cooktop. serial# NF91726384. have not even used it nor treated it as instructed before using. yesterday placed cloth box on top of stove to unload and accidentally turned the large left burner on by mistake. did not even know we had touched it until it burned the box and the material stuck to the stove. we are sick. Stove is brand new. what should we do. can it be fixed or are we going to have to purchase a new cooktop? please help!! can we turn on burner and try to have remainder burned off? thanking you in advance.
  • 855 Answers
You have a couple of things to try, Since it is cloth it would most likely burn off, but I would take a scraper and gently scrape away all excess that I could. Also for flat top stoves there are cleaners you can buy that take off burnt foods etc. and I personally have tried a few of them and they work very well. You should not have to get a new top, that would be silly for such a minor thing. Look at it as accidents happen and now I've had mine with my new cooktop so everything else will be fine. Good Luck!!! And enjoy your new cooktop.
Posted on Sep 27, 2009
Looking for instructions on how to replace the main cooktop on our kenmore elite elecric range, model 790
To raise and lower the cooktop:
1. Remove all items from cooktop and set aside.
2. Grasp the sides of the cooktop and then lift from the
3. Lift the cookop high enough to allow the support rods
to snap into place. The llft-up rods will support the
cooktop in the raised position.
4. If necessary, clean underneath using hot, soapy water
and a clean cloth; then dry.
5. To lower the cooktop, grasp the front corner of each
side of the top while pushing back on each rod with
the heel of your hand. This will release the notched
support. Hold the range cooktop and gently slide the
top back down level to the range.
Aug 03, 2016 | Kenmore Kitchen Ranges
My (new to me) apt has an electric jennair stove top -no instruct
Try http://www.jennair.com/flash.cmd?/#/page/home
Click on cooktops.
I have looked, but cannot find your model number. Perhaps if you look, you may be more sucessful, they do have pics and descriptions.
Oct 15, 2009 | Kitchen Ranges
I'M LOOKING AT A USED COOKTOP BY JENNAIRE MODEL #JEC 8536ADW SERIAL #10672300CC. HOW CAN I FIND OUT HOW OLD IT IS. IT LOOKS ALMOST NEW
How old is my appliance?
Brand: Jenn Air
Type:
Country: USA
Model: JEC8536ADW
Serial: 10672300CC This product appears to have been manufactured February of 2003. (MAYTAG-10)
Sep 29, 2009 | Jenn-Air 35 in. JEC8536A Electric Cooktop
How to replace the glass for whirlpool oven serial # RPO 713144
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself. NOTE: Cook tops are NOT cheap. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
1. Unplug the cook top and leave the elements in place.
2. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
3. Remove the surface element assembly leaving all the elements wired together.
4. Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
5. Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
1. There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
2. Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
3. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
4. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
5. Lower the new cook top into place and secure with screws.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 05, 2009 | Whirlpool SF367 Gas Kitchen Range
Hot Cooktop indicator
You either have a reed or thermal limiter switch that is bad or a switch that is bad. The only way to determine it is with a meter. I think that this job is better left to a professional unless you know how to use a volt/ohm meter.
Apr 08, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Broken cooktop
look just call frigidaire and tell them it just cracked it has a five year warranty the tech don't care he gets his cash his pay for fixing it not being a frigidaire police man just tell him it cracked you don't know why they have a five year warranty could have already been cracked when you got it and you didn't know now couldn't it
Mar 11, 2009 | Frigidaire PLES399EC Electric Kitchen...
White glass cooktop hard to clean
First thing I thought of was that your pots have oil or build-up of some kind on the bottom. Try cleaning them with a solvent of some kind. As an experiment, try using a pyrex pot to see if that makes a difference. As for cleaning the cook top, I use a vinegar and water solution with a soft cloth or very low abrasive scrubber as you can scratch the glass quite easily on some kinds.
Sep 17, 2017 | Jenn-Air JES9860 Electric Kitchen Range
Cooktop manifold gas line size
If this is brand new go back to the makers of the stove. And ask them why don't do any modification's to the stove it could invalidate any warranty.
Mar 19, 2017 | Kitchen Ranges
Front side heat element with ring wont light on ( or heat up)
These type of elements are often known as dual elements. They usually have two separate coils. More than likely the center coil has failed. They cannot be repaired and, in the case with your range, cannot be replaced separately. You will need to replace the entire element. Searspartsdirect.com carries parts for your range. Just type in your model number and locate item numbers 5301 and 5302 under the "Cooktop" heading. I do not know which front element your are talking about, but there is a price difference. No, thay aren't interchangeable. They have different wattage ratings. You will need to determine which one it is that you're having problems with. Replacing a single element is not difficult. It can be accomplished easily by following these instructions:
1. Unplug the range before servicing. Even with the unit turned off, there are potentially dangerous voltages present on the wiring harness.
2. Open the oven door and locate the two screws that hold the cooktop in place under the front edge. CAUTION: Do not put any weight on the oven door. You can cause damage to the door springs. Once you remove the screws to the cooktop, close the oven door.
3. With the screws removed, the cooktop will lift up.
4. Use something to prop up the cooktop, or a second person to assist, and carefully remove the mounting bracket to the two front elements. They are assembled together on the same bracket piece.
5. Gently lay the entire assembly on top of the oven box, leaving the cooktop propped up. Disconnect the wires to the affected element and unscrew the mounting clips. NOTE: There are numbered mounting holes on the element, pay attention to which numbers the clips are screwed into.
6. Remove old element. Install mounting clips to new element and reconnect wires. Install new element in mounting bracket and carefully lift back into place on the cooktop and install. NOTE: Use caution when handling the elements, they are extremely fragile. DO NOT touch the ceramic material, or electric coils with your bare hands. Oil transfer form your hands can cause potential hot spots, leading to premature failure of the element.
7. Lower cooktop and secure back in place.
The repair procedures are pretty straight forward. If you have any questions, please let me know. I hope this helps you.
Aug 18, 2008 | LG LRE30451ST Electric Kitchen Range
Replacing smooth top
Have you purchased a new top yet? If you haven't, you can find it at repairclinic.com for about $270.00 (item #703866). Just type in your model number in the search index and you will find a pictorial part index for your range. The part isn't cheap, but it would potentially cost you twice as much to have a repair service replace it for you. If you still wish to pursue this repair, follow these simple instructions:
1. First of all, UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. Secondly, is the glass top still intact? I know it is broken, but is the glass completely busted apart, or is the top just cracked? If it busted, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cooktop. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4. On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the cooktop and leave the elements in place. Place the whole assembly face down on a soft surface (like some old towels, or a blanket) and remove the surface element assembly leaving all the elements wired together. Place the new cooktop face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place. Install the new cooktop back on the range and you are DONE.
5. If the wiring harness does NOT unplug, there are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
5. Lay the intact element assembly, with wires still connected, on top of the oven box handling the elements with care. they are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of.
7. Use care when screwing into the new cooktop. CAUTION: The scew holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
Good luck and I hope this helps.
Feb 11, 2008 | Maytag MER5770 Electric Kitchen Range
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
