Question about Ford Vehicle Parts & Accessories
Central locking will not lock rear passenger door also cannot lock this door manually
  • 344 Answers
Sounds like a mechancial problem
Posted on Sep 29, 2009
My right side passenger door does not lock automatically anymore. Is there a fuse that operates this.
no all is related to one fuse you can remove the door internal controls and decore and remove center lock motor plug and test two connectors with multimeter with set on 12v and then lock un lock door and check the reading of the multimeter if it read signal then all plugs and wires from central lock control unit to the door central lock unit is okay it this cae you have to replace the door central lock unit with the same if no signal is readed while you lock unlock the door then you have to check central control unit and all wire plus out of it to the door plug
2- you can remove central control unit from driver door and test it in passenger door (usually the same unit ) if it works with lock unlock its then the replaced unit is faulty and needs to be replaced if it not work then check plugs wires from central lock unit (usually found inside driver door ) to the central lock unit in passenger door
3- check signal for said door fro the output of central door unit if no signal then it mean that faulty central lock control unit
Feb 23, 2015 | 2005 Honda Accord
Central locking problem
Change/repair the central locking motor inside the door.
Apr 01, 2014 | 2006 Hyundai Atos 1.1
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
Cannot open passenger door with the remote and the manual key but can lock. only the drivers door opens.
The central locking is faulty on the passenger door it's a common problem on the E90 models you need to renew the latch which contains the central locking actuator
Mar 02, 2013 | 2006 BMW 3 Series
Central locking fault proton impian
Replace the door lock motor for the one that does not lock.
Apr 16, 2012 | Proton Impian Cars & Trucks
My passenger door central locking has stopped
Method 1: Press lock or unlock button 4 times in succession. Method 2: Switch ignition ON and OFF. Within 10 seconds press lock and unlock button in succession.
This is the only manual reset
If this does not work go to your local auto electrician
The probable fault could be central locking activator passenger door
Jul 15, 2010 | 2002 Mini Cooper
406 hdi pass door lock wont lock so car wont lock
Remove the door pannel and spray releasing oil over the central locking solinoid.That should sort it for you good luck.
Sep 02, 2009 | 2005 Peugeot 405
Rear door wont unlock
this is not the dead lock? if i am right in thinkin that this is a centrally locked car then the sensor in the door isd set too low mybe slipped as only has to be out a little to cause this, more of an antitheft system than a dead lock.
Feb 24, 2009 | 2002 Volkswagen Jetta TDI
Vehicle Parts & Accessories Logo
127 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
