Question about Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi washer-dryer zjd 1219
Can you please tell me how much my washer-dryer is going to roughly cost to repair it keeps coming up with the error code 51, I have been told that the motor as gone and its going to cost around £200.00 is this true.
many thanks amanda
5 Suggested Answers
  • 5 Answers
SOURCE: error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
Posted on Jul 18, 2007
  • 641 Answers
SOURCE: how to fit drive belt to zanussi washing machine
Does it a new belt or the existing one ?
Posted on Sep 04, 2007
SOURCE: zanussi washer/dryer zwd1471s
E20 normally means there is a blockage in the drain tube/filter. I have the same problem, but the drain tube is clear. I have searched the web and found the solution being down to the "plastic bottle-like condensor having debris/fluff in it".
Posted on Apr 15, 2008
  • 54 Answers
SOURCE: washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Posted on Oct 15, 2008
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
Zanussi ZJD1219 Washer/Dryer - noisy spin and dirty spots
Sounds like the main drum bearings have failed, and the marks on clothes are probably grease spots from the main bearings.
It is quite an involved repair, and not one that I would recommend you tackle yourself unless you are competent to do so,as it really is involved.
Please rate my solution.
Thanks.
Nov 15, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Error code ed1 on electrolux ewx14540w washer/dryer
The description of Ef 2 is told as error caused of excessive Detergent. Sir, Please consult another expert seperately for code Ed1. To tell, this error code is not described by anyone.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
I have a zanussi turbo dry built-in washer/dryer built-in 1200, Mod zjd . 125, and I do not know how to use it. HELP! Thanks, Cindy
Hey, Just load the washer but do not over load. These combo washer dryers are strictly for smaller loads. You should have a drawer to the left that you place the soap and softer and bleach. Set to the washer to washer. The door should lock automatically. Then set your dryer setting to the the Heat temperature that you want. 100 degrees is ok to start with. then it will adjust itself as it goes through the cycles you have set. Enjoy the machine should work. If it does not look to make sure that the door is closed all the way. Sometimes you have to open the door and reset it and shut the door or while it is closed gently push on it till you hear a small clicking noise. ENJOY YOUR WASHER DRYER COMBO
Aug 28, 2009 | Washing Machines
Zanussi ZJD 125 on a timer switch
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
thanks.
Dec 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi zwf1631w error code e40
hiya
E40 is the fault code for the doorlock, these are relatively cheap and easy to fit and if an independent (non zanussi) engineer was to fit it, you will probably be looking at around £40-£50 all in as a rough guide.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Nov 10, 2008 | Zanussi ZWF1440 Front Load Washer
Washing machine noisey on final spin
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Jul 22, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi ZWD1470W Front Load Washer / Dryer Logo
51 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
