Question about Ryobi Garden
Ryobi chainsaw 4545 automatic chain lubrication not working
    President:
  • 2,220 Answers
That number you provided does not cross to an IPL (exploded parts list) here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches. It is the only illustration I've found that gives any oil line rouling detail.
Oil System Plugged.
A blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at connections. If equipped with an oil pump it is usually behind the clutch (probably left handed thread). The saw can be operated without the bar and chain to verify oiler operation. Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Posted on Sep 28, 2009
My Ryobi chainsaw PCN 4545 overheated
Sawdust/dirt build-up helps cause this situation. Usually, the band is deformed so that it drags. The melted case parts may or may not need replacement, but will likely need trimming. The band usually does as it is difficult to remove the small bends in it. After repair, make sure the chain turns freely by hand. Set and reset the brake several times to make sure it works correctly. The clutch outer drum rarely deforms when this happens. Hope this helps!
Jun 01, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
How to change the oil pump on the chainsaw model pcn 4545
Patrick;
I could not find anything matching the number you provided. I did find an electric saw "RY43006 Chain Saw" here (follow the instructions):
Homelite/Ryobi.com (authorized parts supplier)
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
I think with the IPL as a disassembly guide replacement is pretty easy. There are a couple of hoses listed, I suspect one of them failed rather than the pump.
If this is not your saw please provide some different numbers (reply below) and I will try again. Good Luck. HTH
Lou
Feb 25, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a ryobi chain saw PCN 4545 - won't fire. Is there soemthing simple I'm not doing. Has worked efficiently for 2 years. Don't think it's flooded. Does it have a spark plug ? Would appreciate soem...
A COMMON PROBLEM FOR A CHAINSAW OVER 2 YEARS OF AGE IT IS USUALLY THAT A WIRE HAS BUSTED THAT NEEDS REPLACING CHECK FOR ASSISTANCE IN THE MANUAL IF YOU STILL HAVE IT THERE SHOULD BE AND AFTER CARE PHONE NUMBER FOR FURTHER ASSSISTANCE
Oct 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi pcn3335 chainsaw chainbrake will not release fully
1. Is there a Homelite/Ryobi dealer/authorized repair facility near you? If yes I'd try them they may repair it.
2. Any major chainsaw seller/repairer may be able to repair it... there will be a fee.
Lou
I own a few chain saws without chain brakes. I also own and use good PPE.
Feb 25, 2009 | Ryobi Garden
Same problem as olliee69
Bar oil is delivered to the chain threw a port, usually at the top side of the bar. I recommend removing the bar, apply air pressure to the tank that holds the bar oil. It may flush out debris in this port.
Nov 12, 2008 | Garden
Ryobi Chainsaw - PCN 4545
Ryobi boasts a two year warranty. Have you contacted anyone about a warrantied repair?
An IPL (expanded parts list) for your saw with any oil system detail can be found here:
Homelite/Ryobi.com
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Aug 22, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
349 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
