Question about Home
Bought a corner bath a week ago and it has not got any instructions with it on how to fit the legs on
  • jpintore May 11, 2010
    what brand is it, and does the box have a serial number
    Champion:
  • 248 Answers
Most corner baths have to be fitted securly to the floor and to the wall under top edge some legs are stuck on by double sided pads also some installers block up under seat areahope this helps
Posted on Oct 03, 2009
Bath knight instructions
There is a nut on the backside of the light fitting holding the fitting in place. Remove the nut and the light fitting will come out.
US Parts Center
Jan 27, 2014 | Home
We just bought a womens lakeshore 26" and the assembly instructions are terrible. How do you affix the front wheel?
The front wheel axle fits into the fork, there is a U shaped notch in each fork leg at the end of the fork. There are two washers with bent tangs on them that fit into holes just above where the axle fits into the fork. Slide the washers onto the axle, one on each side. the tangs on the washers should fit into the small holes above each U shaped notch that the axle is in. Next screw on the nuts supplied for the fork. The tire should be centered between the fork legs before you tighten the nuts to secure the front wheel to the fork.
Aug 17, 2010 | Schwinn Cycling
I need leg press rollers. How do I get them? I have a TDS Leg Drive Machine. The nylon rollers or sheaves have broken.
By Phone:You can order by calling our toll free number
1-800-799-8566
7 days a week 24 hrs a day!
Any questions or comments? E-mail Us at customerservice@yukon-fitness.com
Jul 16, 2010 | Yukon Fitness Equipment Yukon Hip Leg Sled...
I am trying to fit a plastic bath panel i have got all the fixings but havnt a clue how to do it! can anyone help?
Assemble the legs & fix to the bath. Leave the adjustment nuts a little loose. Fit taps and waste. Place bath in position. Use a spirit level to ensure lever both front to back and sideways using the adjuster nuts to get it level. Start at one end near the wall and level to the other end against the wall then level sideways. Then check all levels again.
Further help --- rod_davies@hotmail.com
Mar 10, 2010 | Home
Bath waste
! goes over the threaded piece that screws into the piece that goes under the tub...and the other goes between the tub and the waste assembly thereby creating a sandwich with one on top and one underneath the tub....then screw the piece down tight through the tub and into the waste assembly and your good to go.....
Good luck and thanks for rating my effort.....the Fang.
Mar 25, 2009 | Lefroy Brooks BATH WASTE KIT - LB1370-ST -...
Fit my Canon NB-4L Battery
Canon nb-4l battery pack canon 100 percent compatible with you canon nb-4l camera battery. I bought two canon nb-4l battery from http://www.camera-battery.co.uk/canon/nb-4l.htm two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Feb 06, 2009 | Canon Cameras
Waste trap under bath leaks
put the putty under the flange where it makes contact with the inside of the bath, push the flange to the bath & tighten nut underneath. Trim off excess. Have an overflow pipe [not intergral] make sure the top & bottom of the collar have rubber seals
If the whole lot is plastic there may well be a leak down & along the thread of the waste.[it comes from the o/flow pipe collar] Silicone the thread and tighten nut. make sure it's dry first - silicone & water do not make a happy couple
Jan 26, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
Ulysses quirks
I purchased a new 2006 Ulysses about 3 weeks ago great bike but have 2 niggling issues: 1. that damn noisy fan 2. heat on my right leg is more than comfortable Has anyone got any remedies to these problems?1. The fan you can do nothing about. Its very needed but yes it is noisy. 2. The heat on your right leg is a factory standard option. Also not much you can do about it.You could get your header pipe Jet Hot coated and it lowers the temp at your leg a little.,,
Nov 10, 2008 | 2007 Buell XB12X Ulysses
Home Logo
103 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
