Question about Alesis Multimix 8 USB 8-Channel Mixer Spdif System
Clip light on Multimix 12 Firewire always on
After functioning fine for a year the red clip light on this mixer is now always on and accompanied by a constant loud buzzy hum - I suspect it's the transformer, but also worry that the mixer is permanently damaged. Has anyone else had this problem?
I have just gotten the same problem. In my case it worked fine for almost three years and one today I turned it on and this loud humming noise + the red clip light always on appeared. When I hit solo button on channels 9-16 the humming disappeares but the light would not go away. With solo on humming get louder on the mic channels individually (1-8). I am puzzled... No solution so far
Posted on Apr 10, 2010
  • eugene_m Apr 16, 2010
    I found a solution for my problem. I have Alesis Multimix FireWire 16. So the same humming and buzzing problem with the peak light always on. I followed a very simple tip from a post on YouTube (Just type in Google "Alesis capacitor repair").
    Here's what you do:
    1. unscrew the bottom cover panel of the unit (about 10 screws total),
    2. detatchthe bottom part of the unit from the top part unplugging about 5 or 6 different cables.
    3. unscrew the capacitor/power circuit board, that is attached to the inside surface of the bottom panel (its green and is about 4 by 5 inches. can't miss it - its the only one there)
    4. on the board you'll see 3 black cyllindrical filter capacitors. at least one of them will be blown. in my case the 1000mf had its gasket completely bulged out.
    5. replace both 1000 and 2000 filter capacitors. if you replace only one - it might not solve the problem.
    6.re-assemble the unit.
    This should do it. I hope this helps.
I am running multimix 16 usb and had this issue the capacitors had blown I suggest checking this and replacing all the capacitors even if just a single blew out
Posted on Oct 04, 2013
Same problem here...just contacted alesis
Posted on Mar 30, 2010
My multimix 12 has been fine but I just purchased the multimix 16 to replace it. sadly I have the same problem mentioned above. I tried updating the firmware and it didn't help. I contacted Alesis and it suggest that the mixer needs to be serviced....
Posted on Jan 06, 2010
Sorry I do not have any solution, but unfortunately I have the same problem with my multimix 12 fw. Have you found any solution to this yet? I would be thrilled if there were any easy solution such as Firmware upgrade or so....
Posted on Dec 17, 2009
How does work the motor ? with dc 24 volts or ac voltage
if it has a cord attached it is 115 if not it could be 12 volt or 24volt
Sep 03, 2016 | Braun M880 MultiMix Hand Mixer
How do I fix channels with no sound
Mute Switch/Mute-Clip LED :
  • This switch mutes all Aux, Group and L/R sends from the corresponding channel.
  • This switch is equipped with a red LED that will illuminate when the channel is muted.
  • When the MUTE button is out,the LED functions as a Clip indicator that will illuminate at 2 dB below clipping.
  • Muting the channel does not prevent the PFL signal from being sent to the PFL/AFL mix when the PFL Switch (12) is in.
  • This switch mutes its respective Group send from the Group channel.
Go to page 11 in this link :
Peavey FX Mixer Series Operating Manual
You can also try, Restoring Factory Settings, in the Utility Menu Options.
Go to page 16 in ths link :
CAUTION:
Restoring the factory settings option resets your mixer's presets, reformatting factory presets and erasing all other user presets. (This option is handy when your venue has permanently changed and all-new presets are required.)
Once confirmed, the presets are not retrievable and will be permanently lost.
Should you select this option in error, a warning screen allows you to cancel the procedure.
Sep 05, 2015 | Peavey 32fx USB 32 Channel Mixer
Our mixture MACKIE CFX 20 give a humming sound as the clip light always on, but this does not happen before, tell me how to stop this
You say the clip light is always on, as the only clip lights on this mixer are on the effects channel and the master output and you do not say which is on there are a number of possibilities. You may have the effects turned up too far as this should not be showing, just maybe blinking, turn them down on efx2 on all strips as well as on the effects processor and see if this helps. If it does you may be able to find where the hum is coming from by gradually increasing each until you find it.
If you are getting the clip on the main mix master and you are not being deafened and the humming sound is coming from the speakers not the mixer you may have a subsonic signal getting into the mixer. Disconnect all inputs and if this cures it go through until you find where it is getting in and sort that.
If the humming is coming from the mixer it is possible that the smoothing caps on the PSU are dying, you do not say if you are getting normal sound as well as the humming from the mixer.
When asking for help please try to give as much information as possible
Sep 27, 2012 | Mackie cfx20 mkII compact mixer
I can attach the immersion blender attachment but it does not turn on. The machine works fine with the mini-chopper attachment or the beaters. How can I fix this?
Hi
Make sure you use the pulse function of the power switch. Only this position (forward, away from you) will activate the immersion blender, and then at full speed only.
Feb 09, 2011 | Braun M880 MultiMix Hand Mixer
Braun MultiMix 880 became a one speed. Is a replacement switch available?
Apparently the switch is very easily available, unknown for what reason. In Europe they say it is not available at all anymore, which I find strange.
However!
Dissasemble, by removeing base plate and screw underneath curved retainer plstic clip in the front. Then gently pry apart with blunt, thin object to split the two halves. Remember to unplug the power cord first. Check the circuit board for cracks, or burnt components. Then suspect the triac/tyristor. Desolder it and test it with a multimeter. (google "test triac multimeter"). Then note the code on the front of the triac, and search for a supplier of electronic parts to get hold of a new one and solder it back on. Note the orientation of the pins, and reattach heatsink if fitted. (Euro version have non.)The triac often looks like a flat design transistor and have a code/part nr that may look like; TCI 226 N, as on my European 230v version. Electronic components suppliers also have interchangeability lists for different manufacturers and use cross reference lists. Should only costs a few dollars or so. Triacs tend to stay fully open when failed, causing full speed in any mode. It is worth a shot.
Nov 22, 2010 | Braun M880 MultiMix Hand Mixer
My pv6 mixers red clip lights remain on
FIRST check that your power adapter is 16 VAC at 1 AMP and that it is the original unit.
The clip lights monitor levels at several points. If you cranked the EQ's for maximum, say bass, that MAY cause them to illuminate.
As a test, set all EQ's at mid point. Remove ALL input cables. Are the lights still on?
It is possible that you can have a ground loop that is putting signals in that causes clipping. Another source is if you have a microphone that may be FEEDBACKING at supersonic frequency that you can't hear... that is why we disconnect all the inputs as a test.
Finding schematics so one can repair these devices can be a problem. If ALL the clip lights ar on, then it is probably the reference level source for the clip level threshold... however finding a schematic would be necessary and while part cost would be probably under a dollar, the labor and time to find the schematic would be unknown.
Aug 18, 2009 | Peavey 32fx USB 32 Channel Mixer
Clip signal on Alesis multimix 12 USB - no inputs!
http://www.fixya.com/support/t3033553-clip_light_multimix_12_firewire_always
eugene_m has a solution. You have to replace 2 capacitors.
Apr 12, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
Beater keeps falling out. The plastic thing at the top of the beater inside the mixer needs to be replaced. Where can I get the part?
Sunbeam 2366 stand mixer -- Front view: mixer-0-small.JPG -- 0d345a3.jpg-- image of the "beater clip": mixer-1-small.JPG -- notice the wear on the plastic clip --8982711.jpg -- image of the "modified" beater: mixer-2-small.JPG - I took a paper clip an wound very tightly to the smallest diameter (notice it covers the entire section to prevent slippage) and then put one wrap around the "top knot" to increase diameter --d67ddea.jpg -- image of the back of the front cover: mixer-3-small.JPG - notice the broken clip at the top. I used a wide scrapper blade to separate the cover from the main body. 3297c2c.jpg----
Oct 16, 2008 | Sunbeam 2366 MixMaster Series Hand/Stand...
Alesis Multimix 8 USB 8-Channel Mixer Spdif System Logo
1,732 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
