Question about Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 LTD Classic
I have power to unit but no sound. all soders in side are good.
  • 126 Answers
Turn your squelch all the way counter clockwise and your rf gain clockwise. If that doesn't help, try hooking up an external speaker to make sure its not the internal speaker. If these help or don't help, please reply on this thread to let us know, so we can give you more advice if needed.
Dean
Rollin CBs
Posted on Jan 26, 2008
  • Dean Pitts
    Dean Pitts Jan 26, 2008
    Another thing, make sure your coax and antenna are good and tight, and make sure the mic connector is tight. If any of these are not making a good connection, it can stop your receive audio.
  • Dean Pitts
    One more, I don't have a 25 in front of me, and can't remember if it has a CB/PA Switch. If it does, make sure it is up for CB.
    Problem Solver:
  • 19 Answers
Does it have an rf gain on it? if so turn it wide open
Posted on Dec 30, 2007
Peaking and tutuning a cobra 25 ltd classic
Cbtricks.com
25 LTD CLASSIC, VR5 or CUT D9, L10, L9, L8.
Jun 24, 2016 | Cobra Radio Communications
How do i adjust dead key on a cobra 25 ltd classic cb
The only "adjustment" is the AM POWER trimmer. Lowering this will lower your dead key but will also lower your "swing" power. the TX circuit must be modified to lower the dead key and maintain full output. there are many articles on the web for such modification.
Apr 12, 2013 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 that doesn't have any receive
COBRA 25LTD CLASSIC OLD MODEL TRASMIT GOOD MOD GOOD HAS NO RECIEVE
Jun 16, 2012 | Cobra 25 LTD 40-Channels Base CB Radio
No Receive on cobra 25 nw ltd classic cb radio how to fix it
first make sure its on cb not pa. next make sure the squelch is all the to the left. now make sure your volume is open enough not to blast. If you can hear anything you are good if not you need to take it to a tech.
Jun 16, 2012 | Cobra 25 NW LTD 40-Channels Base CB Radio
I have a cobra 25 ltd classic with a 102" whip. It
hello firstly it would be wise to connect your power lead directly to your battery secondly have you checked the vswr on the antenna make sure it is tuned to your radio i presume you have an swr metre and lastly check all coax connection make sure none are shortening out check pl259 at rear of radio and also check lead goin into antenna you can ajust the antenna by raising or lowering the whip .when you acheive 1.5 or better tighten up it should work ok for then
goodluck
Jan 09, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 LTD classic no transmit or receive.I have checked the mic and finals and they check ok. I beleive it might be somewhere in the VCO.Any help
With the radio on, and the case off. Rub your finger gently across the contacts of the audio chip on the trace side of the board. If you hear noise from the speaker it is good. if you don't hear anything(make sure the speaker is hooked up) then the audio chip is bad. You need to change it.
Jan 27, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
How can i connect the volume of my radio
Do you have a Microphone plugged in? No Mike No sound on these.
May 23, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 ltd wx classic
the mics on these cobras have a receive wire in them so the transmit will still work even if the receive wire is broken,if this wire is broken the unit will not make any sound...........remove the plug from the radio end of the mic and check the connections on the 5 pin connector.....(could be a cold solder or broken wire) or try a new mic or one that is proven work on another radio
hope this helps.................good luck!
Dec 18, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
No sound
The Cobra 25 requires the mic to be working for any sound to come out. My suggestion is that you first try a new mic. If this doesn't work, look real close at the board on the soldered side ( around the if section, thats the area that right under the waxed area on the component side of the board ) for cold solder joints ( broken lead solder) You may need a magnifing glass. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 17, 2007 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 LTD 40-Channels Base CB Radio Logo
318 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
