Question about HP Pavilion G60-120US NoteBook
My laptop's screen suddenly became blurry very similiar to how a TV screen looks when it's out of tune. Can you help?
    Problem Solver:
  • 19 Answers
Thats when ur laptop screen does not bring out any image...there will be a display but there will be no image on it......This is common solution to it...All u need to do is troubleshoot the system....The first thing to suspect is the Ram...Some Laptop do select ram...Try changing the Ram and the display will Come back to normal...if that Does not Help then u can Change the Video Memory....Thats the master solution to the problem...
Posted on Sep 27, 2009
  • 103 Answers
Make sure you have the proper display drivers and see to it that u have a supported refresh rate and resolution
Hello, my 55513 tv when turning it on was blurry. after a few minutes it became clear. shut off and came back about 3 hours later and it was blurry again for about 10 minutes. about 10 minutes later it...
in the customer menu select convergence when set acts up---look to see if grid of lines is skewed, see some photos and let me know if your problem anything like this..........
Apr 08, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Blurry vision on picture
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | JVC AV-48WP30 48" Rear Projection...
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
RCA F3250 TV has clouded up.
If you are still getting sound but no picture then its a fair bet than when the tv was moved it was bumped about causing dry solder joints somewhere on the tv probably the line output stage. If you can re-solder the joints yourself try this first otherwise find a competant technician. Hope this helps.
Oct 03, 2008 | RCA F32650 32" TV
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Hitachi Projection tv
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 17, 2008 | Hitachi 43F300 43" Rear Projection...
Sony vgp-vcc1 webcam blurry!
me too. its an aj6 asus laptop. became blurry out of the blue, with no reason! frustrating...
May 15, 2008 | Sony VAIO VGN-FE550G Notebook
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
HP Pavilion G60-120US NoteBook Logo
929 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
