Question about HP Computers & Internet
My hp a1632x will not turn on nothing! the green led is lit on the power supply. the supply was checked with a checker and show good. pulled each plug on drives, memory, etc and reconnect power each time but still nothing will turn on.
  • wd8dfw Sep 28, 2009
    nothing is burned or fried thanks for the input
  • 157 Answers
The power supply can still be good however, if the connection on the motherboard has fried then you need a new motherboard or a new computer which would be your decision.
Posted on Sep 27, 2009
HP Photosmart 7280 all in one. When power cord plugged in, printer will not turn on
Sounds like it could a power supply problem inside the printer or a motherboard component failure. It needs to be taken in for servicing. There is no way to tell what the problem is without an internal review.
Apr 28, 2014 | HP Photosmart C7280 Printer
Power supply LED (Green) turned to red and blinking and nothing works
Power Supply is bad. Plain and Simple. Replace it. Regards, joecoolvette
Aug 31, 2012 | MSI Hp Compaq Evo Ms-6541 Rev 1.0...
First Hello. Before few days,when I turn on my PC(but I was unpluged my machine from electricity) and on monitor displays CMOS wrong set date/time,cpu frequensy.I hit BIOS set up sittings and Windows xp...
Replacing the bios battery was the correct thing to do. Answer me this. The Asus motherboard should have a green LED light lit (Standby power LED), when the system is turned off. Also keep the power cord for the power supply connected at all times. Though it is possible the replacment bios battery was all ready low on voltage or dead. When you're system is turned off the power supply continues to send 5volt DC to the motherboard which maintains the bios 3volt DC.
If the green LED is not lit than there is no power charging the bios battery and every time you boot the system the bios will have lost its settings. If the green LED is red in color, than the problem is within the standby switch built into the motherboard. The standby circuit can not be repaired. Double check all power connectors from the power supply to the motherboard. If everything has a good connection and you're bios settings continue to reset you should consider replacing the motherboard. At this point you have nothing to loose. Install the latest bios update,
(Beta Version 1010.005). 2006/02/14 update.
http://www.asus.com/product.aspx?P_ID=d2Gi3Hr6quXOk51C&content=download
Mike
Jan 23, 2010 | ASUS A7V880 Motherboard
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
My computer won't boot up or something; no power led lit.
Seems to me your Ram module connector is dirty. Clean its edge connector with a soft eraser. Or if it can, transfer it to the next ram bank. Or your memory module is already dead.
Apr 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Pc won't start
try to reset BIOS by CMOS battery from motherboard and insert again...if not worked then..ur motherboard needs to be replaced...
Feb 04, 2009 | HP Compaq dc5100 PC Desktop
I have an hp 754n that will not turn on.. the green led on the back is lit up but when i hit the on off button nothing happens
i would say there is a problem with the motherboard, you could check to make sure the power supply is connected, if you don't know what a motherboard or power supply is, i would advise that you take the computer to a technician, you could injure yourself, or ruin the computer completely if you attack it with a screwdriver
Jan 20, 2009 | HP Pavilion 754n PC Desktop
Computer won't start
The power supply is fried partially, or the motherboard went poof.
Dec 19, 2008 | Antec TruePower 2.0 550W 24/20pin nVidia...
Computers & Internet Logo
106 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
