Question about Pedal Car Renault Megane Trophy
I have a renault megane and there is a small pipe lead next to my battery which looks like a breather what does it do
  • 84 Answers
If its the one that acually comes out of the battery it is a breather for the battry
Posted on Jan 08, 2010
  • Dave Boyle Jan 22, 2012
    Where does this connect to? Mine seems to have come out and i cant seem to figure where to put it back in?
Renault Megane Footwells fill up with water
check your aircon outlit pipe it might be clogged , try cleaning it up and insert the rubber correctly
Mar 18, 2012 | 2005 Renault Megane Scenic
I have a renault megane 1998, central locking suddenly stopped working tested key fob thats OK
It could be your onboard computer or locking module, as the guy next door had an identical problem on his Megane. A tech came and changed a module then programmed the 'brains'.
Oct 29, 2017 | Renault 181 Cars & Trucks
Where is renault megane 1600 cam shaft sensor (the small one)
cam sensor is black sensor next to coil no1 need to remove coil for access to sensor. no1 is gearbox side.
Mar 02, 2010 | 2004 Renault 181
Zigzag light on megane scenic dashboard comes on car revs high then low usually stalls then coming to a stop. 1998 renault megane scenic rt manual. thanks
this exact problem on a megane coupe is caused by a small air pipe that connects to a 2 inch wide black box that is located under the bonnet near the windscreen on the passangers side. the zigzag light indicates an electrical fault (in this case lack of compression and will affect your revs) if you find this pipe and it has snapped off. the reason for this may be that your engien is lose and moves. grab the engien with 2 hands and see if you can wobble it with allot of play. if so your engien mountings need replaceing. you may also experiance juddering in low gears
Feb 15, 2010 | 2000 Renault 181
My friend has an s reg renault megane and says it wont tick over and also has a heart monitor style light showing any ideas?
Dec 12, 2009 | 2000 Renault 181
1998 renault megane ignition problems. My wifes Renault megane scenic 1998 has has nothing but problems since we bought it. The most recent being as follows. I was driving the car and stalled it. from then...
it sounds like one of three things are happening
1.your battery has adead cell in it and does not have enough cracking amps
2. your alternater isn't charging your battery enough
3. your starter is worn out causing it to need more amps to turn over
You can go to your local auto parts store and have them test your battery and charging system usually for free. if the battery and charging system checks out then pull the starter off and have it tested.
Oct 17, 2009 | 2000 Renault 181
Oil leak
in auto gearbox cars there is connection between gearbox and engine. what you connected is a vacuum pipe to vacuum capsule,it for gear changes, it seems it faulty.
Jan 18, 2009 | 2004 Renault 181
Renault megane 225 none runner
checked all leads from pos and earth leads, found 1 earth lead had a brake in it.
Oct 14, 2008 | 1986 Renault Sport
Warning Light on R reg renault megane scenic
hi off your discription sounds like the engine warning light is your car running ok and have you not got the drivers hand book in the glove compartment as this will verify it the engine waring light is basicly for the emmissions on your car you need to get a fault code reading to give you some idea of what if causing your problem it may be a simple fix example blocked air cleaner but i find guessing usually costs you more money in the long run i wouldn,t ignore it though as they are there for a reason yates210456
Sep 29, 2008 | 2003 Renault 181
Pedal Car Renault Megane Trophy Logo
125 people viewed this question
Top Pedal Car Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Pedal Car Toy Expert? Answer questions, earn points and help others
