Question about Dishwashers
AEG 40650 Water heating problem
I have water Heating. The elemaent and the sensor have been changed but still the same. I would be very grateful for any help.
  • cockerchumpy Dec 24, 2007
    Thank you very much for the fix. You are a star. Happy Holidays to you.
The problem is broken heathing relai on the front .
The relai is monting on software print behind the bottens.
Posted on Dec 19, 2007
I have a AEG Favorit 65011 VI (dishwasher) which stops in the middle of a programm an shows error ",60" that is not mentioned in the Users Manual. Can you please help me?
The temperature must increase by a certain amount at each step.
If there is no temperature increase during three minutes, the electronics will generate "Heating Time Out" or fault code i60.
In this case program will continue to the end without heating and the washing result will probably be unsatisfactory.
Could be: Heating element faulty; intervention of safety
thermostats (open); faulty wiring; NTC sensor (poor
thermal contact); insufficient water circulating in the
tub; washing faulty pump (impeller stripped); circuit
board faulty.
Dado
Mar 10, 2015 | AEG Dishwashers
Aeg dishwasher dont worm the water
Could be:
- heating element
- thermostat or NTC sensor
- wiring
- electronic or timer
Dado
Jul 05, 2014 | AEG 24 in. Favorit 3A Free-standing...
AL03, DOES NOT DRAIN AT THE END OF CYCLE, DRAINS AT THE BEGINNING
AL03 - HEATING TIME-OUT
The maximum heating time for the water is 45 minutes; if the correct temperature is not reached within this time, an alarm condition is generated.
Possible causes:
  • Heating element broken
  • Safety thermostat open
  • Wiring interrupted / disconnected
  • NTC sensor faulty / incorrectly positioned / poor thermal contact
Dado
Jun 01, 2014 | AEG 18 in. Favorit 64800 Free-standing...
I have triggered the anti flood system how do i fix this problem?
When this happened to ours it was food debris in the water supply feed. There is a tank located in the left hand side wall which is accessed by taking the side off the machine. This tank needs to be replaced as although it may reset itself a few times the problem continue to occur until the water fill path is clear
Jul 03, 2011 | AEG 24 in. Favorit 40650 Free-Standing...
My dishwasher aeg favorit 50870 not use hot water(not do hot water)
If the water isn't getting hot, then either the water inlet valve that opens the hot water is faulty or the heating element that heats the machine may be bad.
Sep 29, 2010 | AEG Dishwashers
AEG Favorit 40650 water heater not working. How do I check if it is the heater element failure or the printed circuit board control unit
Check the element by using an Ohm meter. You should get an ohm reading if the element is OK. If the element is open circuit you would get an infinity reading. Just note that "newer" machines do not use the traditional heating elements but do have a (Inductive heater) coupled in line with the hose feeding the top spray arm of the washer. This unit must be cheched by a dealer as a DIY will have dificullty checking it.
Oct 21, 2009 | AEG 24 in. Favorit 40650 Free-Standing...
Water not heating. Element replaced with new but still no joy.
The water is heated via a "inductive heater" and not the usual heating elements. This heating device is at the bottom back of the dishwasher and is a cyliderical +/- 15 cm long metal tube. It can easly be removed by the wire clamps at each end. It does have electrical push on connector that just plugs out. If the electrical connections are good I suggest you replace it with a new one (if you can get one).
Mar 23, 2009 | AEG 24 in. Favorit 40660i Built-in...
AEG Favorit 40650 dishwasher is not heating the water or drying the dishes.
Remove the controller from the top of the door. Extract the main PCB from the plastic case. You will probably see a burn mark on the inside of the case adjacent to the relay on the back of the PCB. Examine the back of the PCB for burn marks around the relay pins. Resolder the relay and any damaged track.
May 18, 2008 | Dishwashers
Dishwashers Logo
150 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
