Rank: Master
Rating: 80%, 3 votes
Hi
I will try to help you out with this....
Might be you tried to cinnect with the network many time thats why its keep on disconnecting,
you can delecte all the netwoks that you have in you 3G Iphone and try to connect fresh, if its still give you the same error then you need to change the channel on the router if still it wont connect I suggest you to change tehw ireless settings on you router and reconnect all the computer and you Iphone again with the new network...
Steps are below before you change any settings on teh router i would like to inform you that you will loss your wireless connection till you reconfigure and reconnect you computer with the new network again........
open the internet explorer on your wired computer
type in 192.168.1.1or you can type
http://routerlogin.com, it will prompt you for user name and password, the user name will be 'admin' and password will be 'password', make sure you type it in small case
click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I hope above mention will resolve your concern.....
Thanks
Harmeet :)
