Question about Baumatic MEGAWDSS Front Load Washer / Dryer
My megawdss will not spin everytime can you help
My baumatic megawdss will not spin everytime can you help me.
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Posted on May 02, 2010
Why baumatic rangehood BABT83.2AL stop working
Remove the filters and see if you can see the fan blade. Try turning the fan blade by hand. If its jammed up or tight, you may need a new motor. If it spins freely, turn on the rangehood and give the fan blade a spin . BE CAREFULL when doing this, if the motor starts up and runs properly after spinning it, it could be the start capacitor has failed. If it still wont run or if the fan is tight, you may need a new motor. Spare Parts should be available. You will have to trawl the internet looking for Baumatic parts suppliers in your area.
Jun 27, 2014 | Kitchen Ranges
Making a banging noise on spin and throwing itself around the kitchen. i think the drum has come loose?????
well sort off.
likely is that the dampers on the underside of the drum have failed. (they are like shock absorbers)
The drum is also suspended from a couple of springs, you also need to check these.
To check springs the lid needs to be removed.
There normally are 2 dampers attached to the drum and the frame.
They are accessed by tipping the machine onto its side.
However the machine is heavy and make sure you disconnect power and water if you want to investigate.
Cost of new dampers are around 50 each.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic BFD60SS - Tablet not dissolving
this happened with mine and it turned out that the top shelf was too low, so this meant the spinning arm was being stopped by my plates. When the machine is fully loaded check that the spinners can move freely. if they don't then you can move the top shelf up a level. hope this helps
May 27, 2010 | Baumatic 24 in. BFD60SS Free-standing...
Baumatic washer draining but not spinning
Sep 05, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic megawdss leaks in front when wash cycle starts. How do I fix this?
The front door seal is bad,check to see if there is anything jammed up inside that seal,money,ex,ex,lint
May 07, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic WD55 Washer Dryer - How Do i work it??!
machine needs to be on half load for dryer to operate
Dec 26, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic washing m/c btwm4
check that the drain filter is clear, if thats ok its probably going to be the electronic module at fault.
Nov 25, 2008 | Baumatic BTWM4 Front Load Washer
Baumatic MEGA WDSS washing machine
go onto manualtree.com type baumatic megawdss washing machine, if this does not bring anything up scroll down until you see it in the listings. type in the code it asks for (this will be supplied underneath, its just to stop cumputers auto logging) and then download then manual. good luck
Jul 02, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic MEGAWDSS Front Load Washer / Dryer Logo
119 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
