Question about Epson Stylus CX4800 All-In-One InkJet Printer
New ink cartridge reporting empty - Epson Stylus CX4800 All-In-One InkJet Printer
4 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: The printer tells me all the ink cartridges are empty and refuses to print
Hi Blackburn,
Get you some rubbing alcohol and Q-tips. Disconnect the power from the printer and remove the Ink Cartridges. Using the q-tips and soak them with the alcohol. Clean the electrical connections in each of the cartridge ports. You might go through several Q-tips before geting them cleaned up good. If necessary use Finger nail polish remover instead of Alcohol to get any contaminants off of the connections. Test a site with the fingernail polish remover first before dabbing it all over. I am afraid that it may eat up the electrical connections.
Posted on Nov 24, 2007
SOURCE: Printer reports always "out of ink"
The Stylus CX 4600 gets its jets clogged easily when you don't use it every day or so. Cycle through several times of cleaning the jets and printing the results, until it comes out right. I have had to do this as many as 6 times to get the test print to have no gaps, but eventually, it will always work if you clean them enough.
I have also had new cartridges report empty. I called the aftermarket source where I got them, and they had me return the cartidge for a free replacement. The replacement worked. Sometimes, paying 20% of the Epson cartridge price gets me junk cartridges.
Posted on Mar 30, 2008
yooperbud
  • 8637 Answers
SOURCE: Epson RX420 new black ink cartridges displaying empty
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
I have just changed all the ink's in an Epson d120
If you replaced with "genuine" ink-cartridges, then it should report "full".
If you replaced with "refilled" ink-cartridges, then the company that refilled forgot to "reset" the electronics inside the ink-cartridge, in order to report "full".
Or, perhaps, the software "toolbox" that came with the printer has a button "I have installed new cartridges, please re-verify the ink-levels" ??? Click that button.
Nov 27, 2009 | Epson Stylus D120 Network Edition ultra...
Printing problem
The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly, or a cartridge that wasn't, in fact, properly filled. In other words, your cartridge (or cartridges) may actually be empty, even though the Status Monitor says there is ink in it/them.
You do not say if this problem is one cartridge, or all four. If it is the latter, then something is clearly amiss, since it is unlikely all four would be erroneously reported as containing ink when actually empty.
However, the first step is to buy a new set of cartridges - you can get a set of compatible cartridges from E-Bay very cheaply. You can save the old ones - tape up the nozzles to keep them from drying out - you may be able to use them again when you know what is going on.
Make sure you go through a proper cartridge replacement process so that an ink charging cycle is carried out.
If the new cartridges produce no printing, try a couple of head cleans and nozzle checks. If this still produces no print, report back with a new comment on what you have done so far.
Apr 26, 2009 | Epson Stylus C63 InkJet Printer
HP C6280 with new ink cartridges shows cartridges empty
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Feb 03, 2009 | HP C6280 All-in-One Printer
OfficeJet 9130 incorrectly reporting empty ink cartridge
Look to see if there is dirt or other debris inside the Magenta Ink slot. There is probably something there disrupting the ink flow. Use a flash light to see if ink is clogged. Use Acohol with Q tip to clean the area and reinsert the ink cartridge. Make sure the printer is off and the slot has dried before turning the printer back on.
Hope this helps. Helen
Dec 19, 2008 | HP Officejet 9110 All-In-One InkJet...
HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Aug 03, 2008 | HP Photosmart D7360 All-In-One InkJet...
Cx5500 all in one and use T0731-4 ink cartridges
If you are using a compatible cart and the printer has twice reported the cart as empty when they are new, chances are there is a problem with the printer. You can buy a chip reseter off ebay for a couple of bucks and try resetting the cart. If the machine still reports the cart is empty you either have dodgy chips on your carts or the printer is having problems reading the chip, This could be caused by a bent pin/contact in the print head cartridge receiver.
Feb 09, 2008 | Epson CX4200 All-In-One PSC Printer
Frequent problems with the magenta cartridge of my PIXMA MP510.
Dirty or faulty contacts in the cartridge chamber is the only logical explanation.
Remove the cart and with a cotton wool bud and a little alcohol or similar[NOT ACTETONE it melts plastic] give a gentle clean.
Oct 24, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Sep 23, 2007 | Epson Stylus CX4600 All-In-One InkJet...
HP L7780 always reports empty magenta cartridge
Hi, The issue can be resolved by just shaking the ink cartridge slightly by holding the nob closed so that the ink mixes and then insert the cartridge back in the printer this should fix the issue... You can also power cycle the unit by unplugging the power chord and replugging it back by keeping the printer turn on and make sure that the all the cartridges are out while powercycling the unit, This will fix the issue check ..
Sep 05, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Dell 942 AIO printer cartridge problem
Was your replacement cartridge a new dell product? If it was, the sensor on the prnter should recognize it as new and reset the indicator to full. If, however, the cartridge was refilled, remanufactured, or otherwise an off brand, the ink indicator will show it to be empty. Just ignore and use the printer as normal -- it will print just fine, but you may need to press the select button to get it to start printing the first page.
Aug 26, 2007 | Dell 942 All-In-One InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
