Question about Garden
Westwood 1200 tractor mower adjusting drive belt
Adjusting drive belt
  • 97 Answers
SOURCE: lawn tractor engine dies when pto unit is engaged
Check safety switches especially the seat switch.
Posted on Mar 24, 2009
gisvc
  • 40 Answers
SOURCE: drive belt slips on lawn tractor, cannot see an adjustment.
hi,
i would check with the owners manual to see if it shows an adjustment for the belt drive. most mowers today are equipped with a self adjusting arm witha pulley tensioner with a spring attatched to it. as the belt stretches the tensioner spring pulls against the arm causing it to apply tension to the belt thus tightening it. it sounds as if your belt is stretched beyond the limits of the tensioner. at least every new season it would be a good idea to inspect the belt tensioner for room or space of free play. that is to check to see if it will move opposite the pulley allowing the belt to tighten. if there is not enough sufficient room then i suggest replacement of the drive belt.
Posted on Mar 29, 2009
  • 153 Answers
SOURCE: BELT ADJUSTMENT
There is an idler pulley near the drive pulley under the engine. It is made of plastic and is a common failure. It freezes up and doesn't want to let the belt move. Have you noticed the smell of hot/burning plastic? You can replace it with an original, but it is still plastic. Metal replacements can be had. I think I got some from mcmaster.com so try there. They are a great resource. Shipping is fast and inexpensive and they have everything a guy could want.
Posted on May 28, 2009
  • 32 Answers
SOURCE: Craftsman lawn tractor mower,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Posted on Jun 13, 2009
  • 61 Answers
SOURCE: Roper 16 hp Lawn Tractor: belt replacement
you need to remove the mower deck there you will see the pullys.
Posted on Sep 06, 2009
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
Yth2248 loses speed on slightest grade. new drive belt not helpful
Roy if it is the correct belt and fairly new, check your manual for belt adjustment, if it shows that there is no adjustment the pulleys may be worn out, on a lot of mowers the pulleys are ware items and changed more often to correct slipping issues. The other thing to check is the belt tensioner if equipped, it could be seized, weak or missing spring or it may even be adjustable by cable end being threaded or slotted bolt holes on tensioner arm.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Drive Pulley Replacement On Craftsman Lawn Tractor
Mower Engine Pulley Replacement Craftsman Riding Lawn Mower Repair Part...
Cub Cadet LT1045 Transmission Drive Belt Replacement
husqvarna LGT24k54 drive belt install
Apr 22, 2016 | Garden
How to change drive belt
  1. Step 1 - Loosen tension and remove belt. Locate the adjustment fastener and loosen it. ...
  2. Step 2 - Inspect drive and drive pulleys. Check the drive and pulley wheels. ...
  3. Step 3 - Select correct replacement belt. ...
  4. Step 4 - Install V-belt. ...
  5. Step 5 - Correctly tension new belt. ...
  6. Step 6 - Start the engine.
Mar 24, 2016 | Huskee Tractor Replacement Riding Lawn...
Westwood 1300s red hot exhaust
Get carb. adjusted, way to rich.
Mar 30, 2014 | Briggs & Stratton Garden
I have just fitted a new transmission belt to my westwood 1012, it will go into gear when the motor is off but when the motor is running the gears will not engage when the clutch is pressed
You've probably put the belt on incorrectly or not put the clutch wheel or spring back correctly. When you press the clutch a jockey wheel on the drive belt should release the tension, allowing the belt to slip and the gears to be engaged.
Oct 28, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
I engage the mower blades, put the tractor in drive and the blades stop
sounds like the safety switch is out of adjustment
Apr 06, 2012 | Garden
I have acquired a Westwood T1300 Hydra Ride on Mower but it came without the instruction manual; can you provide me with one, please Roger Dennett Tel: 07816 152 705 rogerdennett@questsourcingt.biz
here is one on ebay. there are also many hits on google
http://cgi.ebay.co.uk/Westwood-S-T-Ride-On-Lawn-Tractor-Parts-Manual-1990-00_W0QQitemZ220485655907QQcmdZViewItemQQimsxq20090926?IMSfp=TL090926143003r8795
Oct 03, 2009 | Garden
Hi, I have a westwood ride on mower & the 3 bladed 36inch deck has started to whine bearings I think? Are they easy to change? special tools? parts off who? the machine is just 3 years old Thanks JT
I assume you are referring to the deck bearings. The easiest way to replace the blade drive bearings is to remove the deck from the mower. You can then easily remove the blades, clean the deck and be able to easily get to the bolts holding the bearings and pulleys in place. This is normally a straightforward repair and can be accomplished with common hand tools. You will need to purchase the parts from the dealer who sells the mower. Replace all 3 set of bearings. On a 3 year old mower ask yourself why the bearings failed. Are you washing under the deck when the bearings housings are hot? That will cause premature failure. Are you greasing the bearings regularly?
Sep 20, 2009 | Garden
Garden Logo
691 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
