Question about Samsung CLX 3160fn All-In-One Printer
Receiving fax I have my # of rings set at 2 and it rings about 8 times before it answers. I also get a lot of messages saying incompatable and no fax comes through. I have had people tell me they tried off and on all day long trying to fax me an order. Is this a common error message for this machine? Thanks, trbrewer@centurytel.net
Hi trbrewer -
Had similar problem (setup for 2 rings, picked up after 8).
Problem was: receiving mode was set to "ans/fax". Once set to
"fax" all was OK.
to set "fax" mode: see page9.4 of manual
Good luck !!
Posted on Feb 05, 2008
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
To check if Auto Answer is on:
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
Check to see if Auto Answer is set to On.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
Aug 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Stopped receiving faxes ten days ago. Can still send faxes. Senders say it just rings and rings. Calling the fax by phone confirms many rings, then fax belltones. What do you think is the problem?
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Jan 28, 2010 | Canon PIXMA MX310 All-In-One Printer
When I fax it says phone off hook. I get a message stating no answer.
Try dialing the FAX-number with your cell-phone.
Do you hear the "ring", or does the telephone-company give you a "busy" signal ?
Some FAX machines are "busy" -- receiving many FAXES from multiple customers -- reprogram your FAX machine to "retry" a few times.
Or, when a receiving FAX runs out of paper, it sometimes refuses to accept "new" faxes.
Nov 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Not receiving any faxes but sending
Note: check your equipment for:
Fax machine must be connected to an answer machine
Receiving a fax automatically:
1 Make sure the Fax Auto Answer light is on.
2 To set the number of telephone rings before the printer automatically receives faxes,
2 Set the answering machine to answer incoming calls before the printer does.
after five rings.
3 To set the number of telephone rings before the printer automatically receives faxes.
Oct 31, 2008 | Lexmark X5470 All-In-One InkJet Printer
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
your HP Officejet, you might have one of the following problems:
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
We are not receiving faxes
My psychic powers tells me it's a brother 1270 fax that is not connected properly????
Jan 15, 2008 | Office Equipment & Supplies
Samsung CLX 3160fn All-In-One Printer Logo
97 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
