Question about Onkyo TX-NR900 7.1 Channels Receiver
Hi, My onkyo txnr900 is a refurbished unit and was good for a while, then I started having problems with dobly digital encoding or something (voices very quiet but ambiance is very loud). Then not long after, the unit will turn on and opperate for certain periods of time (always different time) then make internal clicking sounds and eventually turn off (standby light is unlit, but can see through the units casing, there are some lights on inside at the rear of the unit. is it a faulty capacitor or something. I just want the unit to power up first and the obviously try and fix the dolby decoding problem. cheers drew
  • Official Brand Answer
  • 333 Answers
Hello, I am sorry about your issue, I suggest having the receiver serviced, Thank you, Onkyo USA
Posted on Apr 17, 2017
  • 9 Answers
SOURCE: Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Posted on Aug 14, 2007
SOURCE: Onkyo HT-R501 7.1 reciever issues
you have to get it fixed. same thing happened to my onkyo reciever and they said it was a bad circuit. had to take it to an onkyo tech and have it replaced.
Posted on Oct 15, 2008
larry james
  • 287 Answers
SOURCE: Onkyo TX-DS555 will not switch to Dolby Digital
regulated voltage to the processor circuit like drop in these onkyo after 8 years. This or a small capacitor fails in this voltage line.
Posted on Jul 16, 2009
SOURCE: onkyo tx-sr500; power goes out; standby light blinks
Remove all Wires form speakers
Power on
Push Video1 + StandBy /On
appears Clear on display
Posted on Jan 26, 2010
  • 910 Answers
SOURCE: I have an Onkyo tx-sv434
Could you please confirm you have your system set to Speakers A and that the Surround Mode is set to Dolby Pro Logic?
Have you set the individual speaker volumes during the Test Mode?
Finally could you also please confirm the Model No for your DVR to confirm that this is giving the Dolby Pro Logic Output you require.
Posted on Jun 27, 2011
No video outout
Since it's under warranty there's not a lot you can do. Otherwise if you go inside you will void the warranty.
Tell Onkyo it's faulty, fix it or I want my money back!!
Mar 11, 2017 | Onkyo TX-NR727
I have a RCA VR5320R digital voice recorder. My voice recordings are stored on the recorder, under folder "A," but when I attach the recorder to my computer, eventhough the device shows up under...
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player.
These units are notorious for their failing USB feature.
Mar 09, 2011 | RCA VR5220 Digital Voice Recorder
My onkyo HTR520's center speaker does not work properly on dolby digital, it works fine with music and games. but it doesnt work with movies only, the voices r too low. I have to crank up the volume pretty...
This sounds like a decoder problem rather than a problem with the amplifier section. These units have a test mode, I believe, that sends white noise to each speaker. If that test has correct volume and balance, then the problem is in the digital decoding and processing. The surround processing board probably has a problem and will need to be replaced. Please update this with the results of the white noise test.
Thanks,
Dan
Nov 04, 2009 | Audio Players & Recorders
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Onkyo digital reciever has poping noise when in dolby sound
I have the same reciever, and had the same problem.  Contact Onkyo, this is a known issue where defective DSP chips were used and manifest problems with a popping / clicking sound when using surround settings.  These receivers also have a Dolby Digital input issue that can cause audio dropouts when watching cable or SAT broadcasts that encode DD using a 'newer' broadcast encoding methods.  Onkyo is covering the cost of that repair for me now, even though the receiver is 5 years old now....
Jan 02, 2009 | Onkyo TX-DS797 Receiver
Onkyo MC35T model C707CHX
I have the same problem on a refurbished unit I bought 2 years ago. I read at the time that this is a common problem and you just need to send to an Onkyo service center. There are links on the Onkyo or ShopOnkyo website.
Lousy design I guess.
Mar 18, 2008 | Onkyo MC35Tech CD Shelf System
HDMI SOUND
True HD can only work with HDMI interface and is only available on some newer HD DVDs. Check the DVD to see if the True HD encoding is available.
Feb 11, 2008 | Onkyo TX-SR605 Receiver
Out to speakers only in 5CH mode, or front L/R
set it on dolby digital mode not sterio mode should be differnt modes on a ch only use prologiic or spin the mode dial to doby digital on movie on direct tv wont be dobly fake suround more less but center should work change settings modes
Jan 26, 2008 | Denon AVR-2807 Receiver
Onkyo Integra A-809 input selector switching by itself
This is not an IR problem. Could be just loose connectors and dry joints. You'll need to open the unit and visual inspection of the PCB and connector for abnormality.
Good luck.
Jan 20, 2008 | Audio Players & Recorders
Sony STR-DE545 5.1 Channels Receiver
It sounds like you have unit in setup mode. The "L C R" is Left, Center, Right. You can set balance and volume levels of each with this mode.
Use remote to select 5.1 dolby surround to get unit out of 2/1 "stereo"
Aug 19, 2007 | Sony STR-DE545 Receiver
Onkyo TX-NR900 7.1 Channels Receiver Logo
55 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
