Question about Neoware M100 XPE 1GB FL 512MB RAM-ICA RDP TEEMTALK IE KYBD Network Terminal
HP Neoware m100 hard disk problem !!!
I have got some problem with HP Neoware m100 hard disk BIOS can not load the operating system because it can not read the files from hard disk so what i have to do to solve this problem ?
Emachines screen says no bootable device insert boot disk. I have no boot disk
This error indicates that the system is not able to find a boot-able device to load the Operating System. It could be something as simple as a disconnected hard drive, or it could even be a corrupt hard drive.
You can check if the hard disk is being detected in the BIOS. The key to enter BIOS in E-machines systems are Tab, Del or F2.
If the hard disk is being detected in the BIOS, it could be a faulty hard disk. You can try booting from the recovery partition by pressing Alt+F10 when starting up the computer. If you're able to get into the Recovery Partition, you can try a recovery, but you might lose all your data. If you're not even able to get into the Recovery Partition, you'll need to get the Windows disc for installing the Operating System again.
You can refer to these links for further information:
http://h30434.www3.hp.com/t5/Notebook-Operating-Systems-and-Software/No-bootable-device-insert-boot-disc-and-press-any-key-error/td-p/151244/page/3
http://superuser.com/questions/119307/how-do-i-boot-to-the-recovery-partition-on-an-emachines-d620-notebook
GuruAid
May 05, 2014 | Computers & Internet
Entering m100 bios
Two different problems stated, answering in order;
1) "entering Neoware m100 BIOS"
That would be HP Neoware m100 Mobile Thin Client, Notebook PC.
Do to the two statements back to back like that, I feel I need to explain a few things.
If not then ignore, and come back in a Comment; and set me straight.
BIOS
Basic Input/Output System.
A small program.
Used to be 64KiloByte in size, (64KB), but believe smaller now; plus it's smaller in size for a laptop anyway. (Believe 4KB)
When you press the Power On button, the plastic Power On button presses against a carbon contact switch.
The Power On switch is a Momentary Contact Switch.
Touches (Contacts) BRIEFLY, then opens back up.
Power is initiated to the motherboard.
The first chipset to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are installed, does a Ram Memory count, turns the Processor on; and hands the computer over to the Operating System.
(Windows)
The BIOS program has a BIOS Setup utility. Most of the time just referred to as BIOS Setup.
In the old days was referred to as CMOS Setup.
B) To enter BIOS Setup (utility), watch the bottom of the monitor screen, CLOSELY; after you press the Power On button.
The proper key to press to enter BIOS Setup; will be shown.
This window often goes by F-A-S-T!
Keep your peepers glued to the screen.
Write the key down.
2) Windows does NOT like having the same build of Windows, put over it. Does not like lesser versions being put over it either.
Do to this you have to force it.
Go into BIOS Setup, and in Boot Options; set the first boot device to CDROM.
This way when you put the O/S disk in the optical drive, it forces the computer to boot from the disk.
HOWEVER, things change when trying to put WinXP over Vista, or Win7.
Awaiting reply, please post back in a Comment.
Regards,
joecoolvette
Mar 25, 2013 | Neoware m100 Notebook
Can we format pc by usb drive
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
if you need more help with this post a reply
hope this helps
Aug 24, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
Need to reformat
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to
cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
Dec 20, 2010 | HP Mini 1000 Netbook
Hard disk not aacept formet
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
this will erase you operating system you have to have a operating system disk to load it onto you hard drive or create a partition to load another operating system
hope this helps
Dec 03, 2010 | Samsung SpinPoint V80 SV0802N 80 GB...
I don't have an operating system on my hard drive,and I don't have any way to load a new system.What can I do?
http://h18000.www1.hp.com/products/quickspecs/11755_na/11755_na.html
Gives details.
Implies you can boot off USB port, may need external USB kb & mouse
to change BIOS boot order
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=376810&lang=en&cc=us
Is official help site
May 20, 2010 | Compaq tc1100 Tablet PC
I have a problem with hp dv9000.. the operating system wont boot.. even wen i insert any booting disk, it shows the first screen with hp and its logo and then it becomes blank.. i presume my harddisk is...
Try going to the bios and reset the bios to load factory defaults and then reboot. If the same thing happens try taking the hard drive out and reboot, if the same thing happens again its not your hardrive because it would say no boot disk after post. Iam guesing it may be a bios fault because after the logo it goes blank not while loading the os(operating system).
Give this a try and post back your findings.
Jan 20, 2010 | HP Pavilion dv9700t Notebook PC
New hard drive operating system loaded, now cant find hard drive
check the cables it properly connected or not. after start up press F8 key to check the installed hard drive is detected or not. if it is not, check with BIOS settings
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | HP Pavilion ze2000 Notebook
Neoware M100 XPE 1GB FL 512MB RAM-ICA RDP TEEMTALK IE KYBD Network Terminal Logo
128 people viewed this question
Top Neoware Computers & Internet Experts
David Payne
David Payne
Are you a Neoware Computer and Internet Expert? Answer questions, earn points and help others
